#1 Posted : Monday, 27 September 2004 8:50:42 AM(UTC)
What would be the best way to seperate the rubber mould from the stainless backing/body on some WB Statesman body moulds. I have managed to get some moulds for my Statesman that are not split but the bodies are average where mine are good. I thought I could simply peel the rubber off and glue it to my body but I cannot even get the rubber to lift and the more I try to seperate the rubber using a screw driver or knife the more it seems like I am going to stuff it. Is there some sort of procedure or somthing that I can do, like soak it in something or heat it up slightly to try and soften the glue. I will try anything so I do not wreck the rubber. All advice will be greatly appreciated.Cheers Lee
#2 Posted : Monday, 27 September 2004 9:16:23 AM(UTC)
Try that stuff plumbers use to join plastic pipe, the red solvent not the blue or green glue. I forget the name. You can get it in clear as well so it won't stain.
Apparently it is not very toxic also so is relatively safe. (Guess it would have to be no
#3 Posted : Tuesday, 28 September 2004 7:38:58 AM(UTC)
I think the primer you refer to is basically dyed methylated spirits, ie 99% ethanol.
#4 Posted : Wednesday, 29 September 2004 7:19:39 AM(UTC)
Nah it's definitely not metho, it's ketatone or something like that. Metho won't melt the plastic on the pipes.
#5 Posted : Wednesday, 29 September 2004 7:28:28 AM(UTC)
It is methylethyl ketone.
#6 Posted : Wednesday, 29 September 2004 7:37:41 AM(UTC)
Sorry for butting in Ladies but is any one going to answer my question and JP, read the question!!
#7 Posted : Wednesday, 29 September 2004 7:47:48 AM(UTC)
No you can't bloody butt in whose question do you think this is?
All jokes aside, it was a serious attempt to solve your problem. I don't know if this will work but it's worth a try.
And yes its Ethyl Methyl Ketone.
#8 Posted : Wednesday, 29 September 2004 7:58:39 AM(UTC)
MEK (MethylEthylKetone or whatever) is a dangerous substance and has a swag of OH&S issues surrounding it, so I don't know how readily available it would be to the consumer.
If you're in Sydney I can get a bottle/jar filled with it for you as my
#9 Posted : Wednesday, 29 September 2004 3:57:28 PM(UTC)
Methylethylketone Peroxide (MEKP) is used in fiberglassing, and is readily available.
Just take the blond bit out and you should be right :-)
#10 Posted : Wednesday, 29 September 2004 7:17:09 PM(UTC)
Howdy,
If using MEK you will be right if you wear nitrile chemical gloves (safety shop or good hardware - usually the gloves are blue or green) safety googles and do it out in the open to avoid getting the fumes. the cooler the day the better. If yo
#11 Posted : Thursday, 30 September 2004 6:24:48 AM(UTC)
So after all that crap about methoethoskeletonwhosiemawhatsitshitfucktitxx HOW DO I GET THE RUBBER STRIP OFF THE STAINLESS MOULD????????????
#12 Posted : Thursday, 30 September 2004 7:04:22 AM(UTC)
Don't know about it being all that dangerous every hardware shop has it and every plumber uses it, and the US health and safety people did not think it was obviously dangerous (try Google) but to get the rubber strips off try lifting a corner and dabbing
