#1 Posted : Friday, 1 October 2004 7:37:41 AM(UTC)
Running a quady with automatic choke, and like most of these automatic chokes its fairly dicey on cold mornings. I really want to convert the choke to a manual, wondering how hard it is to do and if there are any information/parts available for this kind of conversion ?
Don't imagine it being to hard, but want to be sure before I start pulling my choke apart.
Cheers.
#2 Posted : Friday, 1 October 2004 8:06:16 AM(UTC)
i did the HQ and it is brilliant.
Just disconncted the link to the Autochoke mechanism, bought a Genuine choke cable and mad up my own mountning for it. Much beter than either the automatic or the Holley electric type automatic.
Good tip is al
#3 Posted : Friday, 1 October 2004 9:46:19 AM(UTC)
Yes, there are many options such as replacing the entire choke body and metal pull-off diaphragm with the older HQ style which can either be connected to a bimetal spring (i.e. divorced choke setup) or to a conventional choke cable (manual) via a SU style
#4 Posted : Friday, 1 October 2004 11:16:40 PM(UTC)
I converted my 350 holley from elec choke to full manual using a $15 universal manual choke kit from Peps auto supplies in Liverpool. Works well and is easy to do.
#5 Posted : Friday, 1 October 2004 11:26:42 PM(UTC)
I did a manual choke conversion to the quaddy on my vb 5l. There's a kit for it made by fuelmiser, it comes with cable and mounting bracket, and all carby fittings. It took about 15 mins to fit. With this kit u just gut the inside of the choke thingy on u
#6 Posted : Saturday, 2 October 2004 8:02:38 AM(UTC)
if you don't need the choke very much then you are running ritcher then what you need to be. you are also posibly losing a couple of horses too.
#7 Posted : Monday, 4 October 2004 2:35:28 AM(UTC)
Thanks for the info mate.
I tried Repco today, they are listed as a distributor in my local area. They did'nt have the conversion kit, but they had the vacumm and bracket part available. $69 !!!
I shot an email off to fuelmiser today for distr
#8 Posted : Monday, 4 October 2004 4:34:26 AM(UTC)
OK. If you really don't find something then it is possible to just install a standard choke cable then open the choke body on the quaddy (remove 3 screws or rivets) and gut/remove all the internals). This will give you a choke body with a shaft in the mid
