#1 Posted : Thursday, 7 October 2004 9:24:15 PM(UTC)
What to do ? The auto-choke RH manifold leaks. Do they all leak ? Ie that fluffy leaky sound through the heater tube hole. It isnt bad, just annoying.
Is it standard practice to put a std exh manifold on, and dump the auto choke manifold. OR do most original auto choke manifolds have a gasket seal to seal the hole. Or maybe exhaust gasket goo.
Any ideas ? Ta John
#2 Posted : Thursday, 7 October 2004 10:37:00 PM(UTC)
ALL Holden V8 manifolds (except L34) have auto chokes. However HX-VL run an exhaust crossover which is used for EGR, manifold warming and choke heat. You need to change your heads as well as the manifold if you want to use a HT-HQ manifold on a later bloc
#3 Posted : Thursday, 7 October 2004 11:55:57 PM(UTC)
Thks Byron,
Sorry forgot to add its a HQ 253 red motor, with Auto choke and a hole near number 7 that makes a bloody horrible fluffy sound.
Ta John
#4 Posted : Friday, 8 October 2004 3:10:19 AM(UTC)
Hi Guys.
Use a RH exhaust manifold of an HX or later, the choke tube & holes are not there on the later manifold.
Dr Terry.
#5 Posted : Friday, 8 October 2004 3:29:06 AM(UTC)
Trublu
Misread your post. I thought you were talking about inlet manifolds. Dr Terry is right.
#6 Posted : Friday, 8 October 2004 4:28:19 AM(UTC)
Thanks guys...I got a RH exh manifold one off a 253 HZ (think it was). It has the casting for the holes, but no holes. Yippee...not more farty sounds !
Ta John
