#1 Posted : Friday, 8 October 2004 8:20:58 PM(UTC)
Hi all, I know you can change an open center to an LSD center in a 10 bolt large sals.
Can you change an open center to an LSD center in a VR-VS diff (not IRS)??? If so, can you use the same crown/pinion like with the 10 bolts??
Cheers Dre
#2 Posted : Friday, 8 October 2004 8:32:47 PM(UTC)
Yep and yep. You can buy an lsd carrier for $550 new. Just have to bolt your crown wheel and
pinion to it and away you go (may need a bearing kit too)
Ive been looking at the same thing recently as well.
#3 Posted : Friday, 8 October 2004 9:41:00 PM(UTC)
AWESOME! New diff here I come :)
Thanks heaps for the info.
Cheers Dre
#4 Posted : Monday, 11 October 2004 10:49:40 PM(UTC)
Crap, I just realised I didn't specify V6 or V8.
I'm talking about V8 Commodore diffs. Does anyone know if this is still the case with V8 diffs?
Cheers Dre
#5 Posted : Tuesday, 12 October 2004 1:38:01 AM(UTC)
yep still the same. the vn-vs diff centres are all the same 4 pinion 28 spline bw78 centres. irs centres are the same as well. all interchangable.
#6 Posted : Tuesday, 12 October 2004 6:23:23 PM(UTC)
Great, thanks very much!
Cheers Dre
