#1 Posted : Monday, 18 October 2004 5:49:33 PM(UTC)
Hi guys,
I have a 92 VP Commodore V6. After parking the car yesterday, the key seems to be stuck in the ignition. The car turns off fine but the key will not come out. I have sprayed some WD40, but this still did not help.
I don't know what else to try, I don't want to take it to a mechanic as they will probably change the whole ignition. There must be another way to get the key out.
Does anybody have any suggestions ?
All help much appreciated.
Cheers.
#2 Posted : Monday, 18 October 2004 7:17:33 PM(UTC)
The wife's VR had the same issue. The key would not come out at times, and worse would occasionally fail to start the car. It had worn tumblers and stuffed springs. There about 10 sets in a VR so a VP should be similar.
I ordered a new tumbler kit f
#3 Posted : Monday, 18 October 2004 7:23:01 PM(UTC)
Thanks for the reply mate, yeah I did not think it will be an easy job. I might try your suggestion of using a locksmith.
Cheers.
#4 Posted : Monday, 18 October 2004 7:24:30 PM(UTC)
Cheers.
#5 Posted : Tuesday, 19 October 2004 7:46:51 AM(UTC)
use a hammer
#6 Posted : Monday, 1 November 2004 3:53:08 AM(UTC)
The only way the key could not be removed is if the key wont turn all the way to the lock position.It may have a faulty lock or housing which can also break internally.The steering also may have been forced.Easiest way is to remove complete housing (one S
