#1 Posted : Tuesday, 26 October 2004 12:06:03 AM(UTC)
Does anyone know if non air con, and factory aircon heater cores are the same? I have a HZ with factory air and the dreaded green fluid down the firewall is happening!! I have a good non aircon core at home, just wondering if it's compatible?
Peter
#2 Posted : Tuesday, 26 October 2004 3:48:39 AM(UTC)
Hi Peter.
No, the A/Cond & non-A/Cond heater cores are totally different, in size & shape.
Dr Terry,
#3 Posted : Tuesday, 26 October 2004 9:48:38 AM(UTC)
The main difference is that the pipes are a different shape. I think the rest is the same. Maybae you can swap the header tank over to a good replacement.
#4 Posted : Wednesday, 27 October 2004 5:46:42 PM(UTC)
Yes that's what a radiator joint told me too John, anyway they are different, so I'll have to find one of those now!!
Thanks for the replies
Peter
#5 Posted : Thursday, 28 October 2004 9:19:18 AM(UTC)
They are available new on ebay now and then, also I have one out of a VN, it is very similar, maybe you could get one and get the tanks swapped over. The VN would be a newer one, less chance of leaks.
#6 Posted : Thursday, 28 October 2004 2:36:51 PM(UTC)
Don't the VN runs (like most commodores) run a higher pressure cap than the HQ-HZ?
That would be an advantage of having an "over-engineered" VN one if it can be made to fit.
#7 Posted : Friday, 29 October 2004 9:18:14 AM(UTC)
Dunno but if so you would be right. I will dig out the vn and hq ones and do a proper comparison.
#8 Posted : Sunday, 31 October 2004 7:46:35 AM(UTC)
VN one is much thicker amnd slightly larger, and the pipes gop in the wrong direction, but I still think its a possibilty with mods.
#9 Posted : Tuesday, 2 November 2004 8:34:38 AM(UTC)
If still looking I have hz ac heater cores 1 lose 1 in ac box
