skidmark Offline
#1 Posted : Friday, June 10, 2016 10:38:58 AM(UTC)
skidmark
Just wondering how to fit a RSP GTS badge #B1047 to the HT grille. I ask because I can't get the badge to fit neatly flat against the horizontal plastic bars because of the 4 tabs on the rear of the badge which stop the badge from fitting evenly on the grill bars. If the badge is lined up evenly between the grill bars vertically, these tabs are slightly fouling the ribs on the grille because they are spaced 1mm further apart than the gap between the grille bars.
Also, how is the badge held onto the grill using the supplied push on clips as these don't appear to contact the grill. Thanks
Edited by user Friday, June 10, 2016 12:46:56 PM(UTC)  | Reason: Not specified
ht307munro Offline
#2 Posted : Saturday, June 11, 2016 1:27:00 PM(UTC)
ht307munro
Mate I had the exact same problem. The clips they provided are usless. I had to make up some little retaining clips and used speed nuts to put them on (unfortunately broke one pin on the badge). Yes it was tight fitting it to the grille (had to use force to push it on).
Alex
skidmark Offline
#3 Posted : Saturday, June 11, 2016 5:09:03 PM(UTC)
skidmark
Thanks Alex. Looks like I'll have to do some modifications to put them in properly.
Ausjacko Offline
#4 Posted : Monday, June 13, 2016 12:12:01 PM(UTC)
Ausjacko
here is a shot of the clips I think you need:
skidmark Offline
#5 Posted : Wednesday, June 15, 2016 11:54:22 AM(UTC)
skidmark
Thanks ausjacko. Did you make them?
Ausjacko Offline
#6 Posted : Wednesday, June 15, 2016 2:52:50 PM(UTC)
Ausjacko
nope, they came with the car. I just cleaned them up including the badge.
skidmark Offline
#7 Posted : Tuesday, July 5, 2016 11:50:38 AM(UTC)
skidmark
To complete & finalise this topic, Rare Spares contacted me & investigated regarding the HT GTS badge and they have agreed that the badge design requires changing so that it correctly fits the grille.
This page was generated in 0.108 seconds.
