That range was an educated guess, but sometimes the cars don't fit with others or the engine may not be original one fitted in the Dandenong assembly plant. For this reason I'd do the AOMC search as I suggested in the PM so you can ensure that engine was first registered with that chassis number and if it's not the AOMC records will tell you the car it came from (assuming of course its first rego was in Victoria). The BODY number off the body ID plate and the PSN will help in nailing the car better too. |
Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
Firewall number 41132M, steering box 12M8 had a 24-12-68 delivery date
Originally Posted by: bazza30555 Firewall number 41132M, steering box 12M8 had a 24-12-68 delivery date Is that a GTS327? |
That would have been just in time to be a nice xmas present for someone Bazza30555.
Not being a 327 may affect the chassis number timing vs build date. Remember they ran out of 327's and had vehicles (as in completed bodies) waiting for them and vehicles waiting to be built for them. Edited by user Saturday, October 8, 2016 9:06:38 AM(UTC)
| Reason: Not specified |
Sure was a good christmas present, my cars original owners brother got himself one at the same time. First saw both of them in a farm shed in 1972 and thought I wouldn't mind one of them. In the late 90s one of them was in my shed.
Nice, what colour is it Bazza?
Bright blue / parchment & black
A couple more questions if i may. Which booster should it have and also which sub frame as well. Thanks.
Joined: 7/29/2006(UTC) Posts: 763 Location: in the shed
Thanks: 8 times Was thanked: 14 time(s) in 13 post(s)
Brake booster should be a VH305 for your car. Your subframe will have what looks like a battery tray area at the front of the drivers side wheel well, it wasnt for a battery tray though. Search the forum theres loads of info on subframes here.
Wayne |
"I would never want to be a member of a group whose symbol was a guy nailed to two pieces of wood" (George Carlin) |
1 user thanked RigPig for this useful post.
Joined: 4/30/2016(UTC) Posts: 83 Location: Canberra Was thanked: 4 time(s) in 4 post(s)
RigPig. using that code would dot under the A of safety and dot over the L indicate 2nd 1/4, April, May or June of 1968 Those numbers are on a 1/4 vent window on a HK Monaro from Canberra. Early Sept. build I believe. All the other side glass is dot over the L and dot under the F. Given that the 1/4 vent glass is the same across the HK-T-G series 2 and 4 door there probably was a big demand for a part like that that was needed for all models.
Originally Posted by: tbm Hey Rigpig, my chassis number is HK40829 MM So only a few hundred before yours so i guess that makes sort of sense. But it doesnt really fit with the chassis numbers that HK1837 mentioned in his post above. Hey Ron, I forgot to mention you should check inside your steering column. Your car was 273 cars before mine on the line and the same guy may have slipped a brodacast sheet in there 49-years ago. Its worth a look. |
Wayne, chassis numbers on HK-HG don't dictate the order they were on the assembly line. With 273 numbers apart they could be consecutive cars or be a week or more apart if a car was delayed after the car left the body plant. I agree it is worth checking though, the same dude may have done the same trick on many cars. |
Originally Posted by: gm5735 The gearbox stamp is a 4 character date code. It is stamped on the main case below the reverse shift linkage point, and not the shift plate. As it was almost certainly done in the US it could pre date the car build date by up to 6 months. The model code and other build information was written on the bare metal firewall in texta and the xylene from the texta survives etch prime, red oxide and body colour painting and baking. It can often be seen after the paint is stripped, although sandblasting may have removed it. The build date may also be there. You may find a light date stamp on the axle tubes, but not always. The HK differential is different from HT and HG in several ways. As Terry and Byron have said, the actual build date may differ by several weeks from the parts dates and the engine number will be the best indication of build date, as will the information from the body tags. Hi Gm5735, I found a date code on my gearbox which says 8H14 and at the start but slightly lower is R. Can you tell me anything from that? Thanks.
Originally Posted by: RigPig Originally Posted by: tbm Hey Rigpig, my chassis number is HK40829 MM So only a few hundred before yours so i guess that makes sort of sense. But it doesnt really fit with the chassis numbers that HK1837 mentioned in his post above. Hey Ron, I forgot to mention you should check inside your steering column. Your car was 273 cars before mine on the line and the same guy may have slipped a brodacast sheet in there 49-years ago. Its worth a look. Hey Wayne, nope, not there in mine, bugger.
Joined: 4/21/2017(UTC) Posts: 293 Location: Tolmie Thanks: 2 times Was thanked: 24 time(s) in 24 post(s)
I know this is about date codes but with my v8 hk's the out rigger on the front crossmember has a swab of paint on either side at the tip. I presume this was for id on the process line so a v8 crossmember could be installed when needed. the swabs are thick with brush marks as if they were almost tar. one side is grey and the other pink. has anyone else got these markings?
Originally Posted by: KBM I know this is about date codes but with my v8 hk's the out rigger on the front crossmember has a swab of paint on either side at the tip. I presume this was for id on the process line so a v8 crossmember could be installed when needed. the swabs are thick with brush marks as if they were almost tar. one side is grey and the other pink. has anyone else got these markings? I havent seen one in pink before they're usually white. I'd say they were check marks to indicate that all components on either side of the front crossmember assembly had been tightened and checked before installation. Maybe two people worked on it that day and maybe the apprentice was given pink. A date code was later stamped over the painted check mark on the passenger side and usually a crossmember part number stencilled on top between the engine mounts. It then sat in a pile of other crossmembers ready to be installed. I found one check mark on my diff inspection plate probably to indicate oil had been added. I found a couple of others on the brake components and wheel rims, not many though. |
Originally Posted by: KBM I know this is about date codes but with my v8 hk's the out rigger on the front crossmember has a swab of paint on either side at the tip. I presume this was for id on the process line so a v8 crossmember could be installed when needed. the swabs are thick with brush marks as if they were almost tar. one side is grey and the other pink. has anyone else got these markings? My HJ Premier is covered with paint dots. I think Wayne is spot on to their purpose. AFAIK V8 HK would have had the crossmember installed into the car and the engine in from above later in the process, whereas 6cyl would have had the crossmember with the driveline on it and the car dropped onto the assembly. The broadcast sheet would have a code on it so the correct crossmember was prepared ready to go at the appropriate time. Pagewood used a two digit code unique to the car so that the right parts went to the right car, not sure how other assembly plants did it. |
