Thanks: 13 times Was thanked: 27 time(s) in 25 post(s)
Originally Posted by: HK1837 They are steel, as far as I can recall all the ones I wrecked out were anyway. Headlight surrounds are plastic. The early WB ute p van and 1 tonne were pressed steel but coloured to look plastic, so the last steel would of ended in 1980. And the first plastic was the HB S2 Torana 1968
Joined: 11/09/2016(UTC) Posts: 209 Location: OZ Was thanked: 23 time(s) in 22 post(s)
Originally Posted by: castellan Originally Posted by: HK1837 They are steel, as far as I can recall all the ones I wrecked out were anyway. Headlight surrounds are plastic. The early WB ute p van and 1 tonne were pressed steel but coloured to look plastic, so the last steel would of ended in 1980. And the first plastic was the HB S2 Torana 1968 Afaik the 1st 4cyl Torana with a plastic Grille was the 1974 TA.
Thanks: 2 times Was thanked: 28 time(s) in 27 post(s)
Originally Posted by: HK1837 Originally Posted by: commodorenut Are you guys forgetting about the WB Caprice? It would be the last steel (albeit stainless) grille on a Holden. It is alloy. Cast alloy surround (same as Deville) and aluminium fins. It did have steel screws holding the fins to the surround! HD to HG are also not steel they are alloy. They too had steel screws.
Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
Which Holden was the first to have the opel 4 spd fitted to it
Originally Posted by: bazza30555 Which Holden was the first to have the opel 4 spd fitted to it HR Holden with 186S.
Thanks: 1 times Was thanked: 485 time(s) in 463 post(s)
I don't know the answer to the question I asked. Yes it was an option on HR but was it tested on the HR or maybe even HD or EH ?
Originally Posted by: HK1837 Just 186S? Not confined to 186S but I'm guessing a 186S was the first.
I would have guessed it was actually fitted to a HD initially for Engineering purposes, Dr Terry may have a better idea. |
I think the first Opel 4sp box was an option and she only came in after the HR X2 came about. That 4sp box was made in Asia in a chook shed. I would say it was behind some Opel Vauxhall 6 cyl and fully tested over there, some difference may be so to our box behind the big 186.
Thanks: 7 times Was thanked: 11 time(s) in 11 post(s)
What sort of cogbox did the HB Torana have ?
It is later than when HR was available with M20 though. |
Originally Posted by: Warren Turnbull Originally Posted by: HK1837 Originally Posted by: commodorenut Are you guys forgetting about the WB Caprice? It would be the last steel (albeit stainless) grille on a Holden. It is alloy. Cast alloy surround (same as Deville) and aluminium fins. It did have steel screws holding the fins to the surround! HD to HG are also not steel they are alloy. They too had steel screws. The slats of an HD or HR grille are stainless steel while the centre bar is diecast alloy. AFAIK this style of grille construction, i.e. stainless steel slats with diecast alloy surround or centre was commonplace from FE to HR. HK onward contain more alloy. Dr Terry |
Originally Posted by: castellan [quote=HK1837;169456] And the first plastic was the HB S2 Torana 1968 AFAIK the only Toranas with plastic grilles are the LJ 6-cyl & the TA (1974 4-cyl). All others are aluminium. Dr Terry |
Originally Posted by: detective What sort of cogbox did the HB Torana have ? All the HB-TA 4-cyl Torana manual gearboxes were pure Vauxhall. Dr Terry |
Originally Posted by: HK1837 It is later than when HR was available with M20 though. The HB came first. From memory the M20 HR was released about 3-4 weeks after the HB. Dr Terry |
Originally Posted by: Dr Terry Originally Posted by: HK1837 It is later than when HR was available with M20 though. The HB came first. From memory the M20 HR was released about 3-4 weeks after the HB. Dr Terry The HB had a Vauxhall 4spd transmission so the HR is still the first Holden to have an OPEL 4 spd fitted? The HA Viva was the first passenger vehicle that GMH sold in Australia with a 4spd manual transmission as standard but as we all know it isn't a Holden.
Originally Posted by: Dr Terry Originally Posted by: castellan And the first plastic was the HB S2 Torana 1968
AFAIK the only Toranas with plastic grilles are the LJ 6-cyl & the TA (1974 4-cyl). All others are aluminium. Dr Terry Exactly what I thought except all Torana from LJ onwards have plastic Grilles. So that means the HT would be the first Holden with a plastic radiator grille? Edited by user Monday, 24 October 2016 12:27:22 PM(UTC)
| Reason: 'cause I can.
Originally Posted by: 8D11PCH2 Originally Posted by: Dr Terry Originally Posted by: HK1837 It is later than when HR was available with M20 though. The HB came first. From memory the M20 HR was released about 3-4 weeks after the HB. Dr Terry The HB had a Vauxhall 4spd transmission so the HR is still the first Holden to have an OPEL 4 spd fitted? That is correct, I was only commenting on the timing of HR vs HB, not the Opel box thing. Dr Terry |
Originally Posted by: Dr Terry Originally Posted by: castellan [quote=HK1837;169456] And the first plastic was the HB S2 Torana 1968 AFAIK the only Toranas with plastic grilles are the LJ 6-cyl & the TA (1974 4-cyl). All others are aluminium. Dr Terry Not sure how I ended up in the quoted text Terry! |
