Fastlane
Holden Forums
Holden Technical Talk
Info required on HJ GTS Chassi numbers
Hi help required I have a HJ GTS sedan and have a chassi number that is weird it is (wrepaem75c02). Has any one seen this before? Any info appreciated. This does not match the tags Cheers Raz
Looks like the ramblings of a mad person! Is this on rego papers or actually stamped? Post up a photo if it is stamped. |
Yes actually stamped on chassis rail. sorry not sure how to post pic on this forum. The tags have the standard number. So not sure what it means????
Thanks: 3 times Was thanked: 34 time(s) in 33 post(s)
I'd be guessing its some sort of Police/dept of roads replacement number if the original rails were replaced at some stage. You in WA? Seen a similar number on a vehicle from there before.
Car was originally from WA so I guess that's possible
Fastlane
Holden Forums
