HGV8 Offline
#1 Posted : Friday, 2 December 2016 9:43:43 AM(UTC)
HGV8
Was thanked: 10 time(s) in 9 post(s)
This is an unusual spec HJ. Belmont, bucket seats, 308 and on radials.
Jim
j.williams
#2 Posted : Friday, 2 December 2016 11:07:53 AM(UTC)
According to the decal on the rear screen it also has factory air conditioning.
Also how can we tell it's an HJ from that photo ? It could be an HX. The original photo may have a date on it.
HGV8 Offline
#3 Posted : Friday, 2 December 2016 4:27:56 PM(UTC)
HGV8
Could be a HX but the car facing the camera in the distance has a HJ grille by the looks of it.
j.williams
#4 Posted : Friday, 2 December 2016 4:30:00 PM(UTC)
Was thanked: 34 time(s) in 33 post(s)
Did they not drop the Belmont badge by HX? Or was it still on export cars. Also badge placement on the boot is HJ, I think they swapped them for HX?
anonymous Offline
#5 Posted : Friday, 2 December 2016 5:14:51 PM(UTC)
anonymous
Boot and front guard badges are where HJ's had them placed
HX have a script badge above the belt line on the front guard also HX engine size and script are swapped onto the opposite with script on the LH side of the boot.
 1 user thanked anonymous for this useful post.
Lingus on 3/12/2016(UTC)
detective Offline
#6 Posted : Friday, 2 December 2016 6:23:35 PM(UTC)
detective
Consular car.
#7 Posted : Friday, 2 December 2016 8:02:36 PM(UTC)
It isn't a HJ grille, as HJ and HX Belmont (and HJ and HX Holden in commercials) share the same grille other than those with XU3 or XX7 option in HX which use a HX Kingswood grille painted black. However as Anonymous says HX have the Belmont badge and if a V8 the size badge swapped compared to HJ. I'd guess they are going to NZ, they had limited options in driveline compared to what we could get here.
#8 Posted : Friday, 2 December 2016 9:10:34 PM(UTC)
I would say HJ judging by the Holden tailgate badge on the ute on the crane.
ExportHolden Offline
#9 Posted : Saturday, 3 December 2016 5:52:24 AM(UTC)
ExportHolden
Did Belmont badging stay identical from HJ to HX? Just wondering, because Kingswood became cursive script for HX, silver with black outline. I've never heard of a HX Belmont - did they really produce them?
This might be a consular fleet order.
We had one at the Australian Commission in Hong Kong in 1979. It was a HZ Kingswood (not SL), so it looked a bit like what taxis in Australia looked like back in the day. Hubcaps, not full wheel covers, no side rubbing strips, no bumper rubbing strips. Bench seat, column shift auto.
And 5.0-litre V8 and air-conditioned. I still have the owner's manual for that car, not filled out unfortunately. I have a pic of the car somewhere, I'll see if I can dig it out.[img]null[/img]
Edited by user Saturday, 3 December 2016 5:58:59 AM(UTC)  | Reason: Not specified
#10 Posted : Saturday, 3 December 2016 6:46:05 AM(UTC)
Yes, same badges, same grille. 8WN35/69 A9K was introduced in HZ as a delete option on the standard Kingswood SL wagon/sedan as 8WM35/69 was dropped at the end of HX. Although they aren't around today a HJ or HX Belmont wasn't uncommon although finding V8 examples in Australia would be rare as they'd almost always be retail or fleet order - the stock order vehicles would be almost exclusively 6cyl.
#11 Posted : Saturday, 3 December 2016 6:47:54 AM(UTC)
HJ-HZ used the same metal badge, WB had a plastic one from memory that looked very similar.
#12 Posted : Saturday, 3 December 2016 3:24:02 PM(UTC)
ExportHolden
This is the HZ I mentioned above.
#13 Posted : Saturday, 3 December 2016 7:30:05 PM(UTC)
Yes, Phil, the HZ Kingwood (non SL) was basically the replacement for the old Belmont, which was last made in sedan & wagon form in the HX. Where a lot of confusion occurs is that the Belmont utes & vans (which were far more commonplace than sedans & wagons) were last seen as HQs. Most A9K Kingwoods I saw were Taxis or Govt. cars, wagons were very rare.
As HK1837 has said, HQ-HX Belmont were not uncommon in the 70s, but they are a bit thin on the ground these days. Again, something like a 308 Belmont with bucket seats & a 308/5.0 V8 was usually a special order & as can be seen by the pic above, for export.
Having said that, I can remember from my days working as an installation tech. in the Sydney Taxi industry during the early 70s, quite a few of the private operators did order Belmont V8s with air con, p/st & buckets, back when petrol was around 50c a gallon !!
detective Offline
#14 Posted : Saturday, 3 December 2016 7:45:04 PM(UTC)
detective
Whatever model / series it is it must be a " first of " (or close to ) going by the " export Holden " labels in both rear door windows....A promotional photography walk around whereby other " better " pictures would have been used in whatever publications GMH would see fit to place them in.
Edited by user Saturday, 3 December 2016 7:50:53 PM(UTC)  | Reason: Not specified
Lingus Offline
#15 Posted : Saturday, 3 December 2016 11:52:01 PM(UTC)
Lingus
It is a 5.0 litre HJ Belmont sedan and appears to mirror the specifications of W.A.'s police Traffic Patrol cars of the period, prior to the government shifting over to 5.8 litre XB Falcons ... this coincided with the creation of W.A.'s Road Traffic Authority and a change in fleet colours ... the HJ's were dark blue with white roofs, the XB's all-over white with specific RTA graphics replacing generic Police signage.
The 5.0 litre Belmonts were kitted out with bucket seats and 4-speed manual transmission and an extended instrumentation cluster with coolant temperature and oil pressure gauges ... the interiors were otherwise basic, right down to the standard rubber floor matting. Uniroyal Wildcat radials were the 'new' performance tyre of 1974 and these were a fleet fitment on the W.A. patrol cars.
What I don't recall in the patrol cars was factory air-conditioning, and this feature on the Export car in this topic thread suggests to me that the car was likely bound for an Asian destination where air-conditioning would be a very desirable option (as opposed to a temperate situation such as in New Zealand).
justgm Offline
#16 Posted : Sunday, 4 December 2016 6:31:24 AM(UTC)
justgm
Yes , this picture of that HJ has always interested me as well. I think it maybe off to the islands ....Fuji Police ? Very rare to see an air cond car in NZ at that time . Also with the cars being sling lifted onto the ship would indicate an island destination . Mark.
#17 Posted : Sunday, 4 December 2016 6:47:17 AM(UTC)
True my mistake.
#18 Posted : Sunday, 4 December 2016 7:01:06 AM(UTC)
Back in the early 90's I jumped in a VN or VP taxi. It had a V8 in it. We asked old mate how they could afford to run one in a taxi. He reckoned at the time that on gas it was not too bad. He said there was a couple of them getting about. Seemed cool to have a V8 taxi but I bet the economics didn't really work too well.
#19 Posted : Sunday, 4 December 2016 7:50:38 AM(UTC)
I checked the HJ features manual, and for 5.0L in HJ Belmont sedan and it was available for Australia and export excluding: GM-Malaysia, GM-NZ, GM-Thailand and GM-S.A. So it could be Fiji as already stated, Korea etc. The Reefer ships were PO freight from memory and went everywhere around the Orient and the Pacific. You can see on this link the Italian Reefer was a 1968 acquisition.
https://en.wikipedia.org/wiki/J._Lauritzen_A/S
Lingus Offline
#20 Posted : Sunday, 4 December 2016 11:07:16 AM(UTC)
Lingus
I checked the HJ features manual, and for 5.0L in HJ Belmont sedan and it was available for Australia and export excluding: GM-Malaysia, GM-NZ, GM-Thailand and GM-S.A. So it could be Fiji as already stated, Korea etc. ...
Forgive my ignorance, but what is a "features manual" ?
HK1837's information slims down the range of export markets, but South Korea is off the list because it is a Left Hand Drive market ... so too is the Philipinnes (where they used to assemble LJ and LH Toranas in LHD configuration), Myanmar - the former Burma, Vietnam, Laos, and Cambodia.
When you then exclude Malaysia and Thailand, as suggested by HK1837, that leaves only a few markets remaining, firming up Hong Kong or maybe Singapore, Brunei, Papua New Guinea or an Indonesian destination ... or one of few Right Hand Drive destinations in the Pacific, such as Fiji.
Edited by user Sunday, 4 December 2016 11:10:44 AM(UTC)  | Reason: spelling error
This page was generated in 0.105 seconds.
