Joined: 25/12/2015(UTC) Posts: 156 Location: melbourne
hi all , I have a 327 Adelaide build 327 and the engine number is stamped fairly roughly, just want to know if one of you guru,s can help me it indentify it as a genuine engine , it is stamped 32776407 date code k1107h5, thanks..someone told me that the date code should start with a T and not a K not quite sure, any help greatly appreciated.. Edited by user Wednesday, 14 December 2016 9:18:00 PM(UTC)
| Reason: Not specified
It is not an original number. |
ok thanks I was going to buy this engine but if its wrong then no way.. seems to 2 out of 3 engines I find have been tampered with or wrong numbers, I,ll keep looking, thanks again..
Did you look at the number. This engine number is recorded in an original GTS327 already, but it has been altered. I wonder if someone has made a clone engine number? |
the casting number is 3932386..i thought it was a series one engine but is not I think the casting is series two..i have got him to clean the engine number up with a bit of sandpaper..date code is K1107H...there is no five on the end as first thought.. so I don't know if that makes any difference or not.. thanks again..benny..
It does, no such thing as series1 or series2 though. HK had type 1 327 and type 2 327 but that is it That engine is from an Elizabeth assembled GTS327. I think the original car's full details are recorded, it is probably best destined for that car. |
so it is correct 327 engine, if you can find any of the other info or what or who owns it now let me know please..thanks again..benny..
Without the 5 it is an original number recorded in the past. Whether the stamping is original or the block is original, no idea. Edited by user Friday, 16 December 2016 8:10:57 PM(UTC)
| Reason: Not specified |
did they stamp some of them very roughly. numbers are all over the place..
