Whippet Offline
#1 Posted : Thursday, 26 January 2017 5:19:20 PM(UTC)
Whippet
Looking for information on how the speaker is fitted to the underside of the dash board below the grilled area?
#2 Posted : Friday, 27 January 2017 6:36:23 AM(UTC)
It is mounted on a dedicated sheet metal bracket, held in by 4 small self-tappers. There are 4 dimples which need to be drilled to allow its fitting, 2 into the plenum & 2 behind the crash-pad.
The original speaker was 9" x 6" - 15 ohm.
Whippet Offline
#3 Posted : Friday, 27 January 2017 9:27:41 AM(UTC)
Whippet
Thanks found the raised dimples the 2 behind the crash pad have holes drilled already and the 2 near the plenum are not drilled .
Just wanted to be sure I was drilling in the right place ,you would think Holden would have them all pre drilled thanks for your help.
Have you had any experience with the retro genuine looking radios on the market I have found 2 different suppliers one in Sydney and one in Queensland they are similar but by the one in Sydney is more expensive but has a very genuine looking facia
