3 Pages123>
bazza30555 Offline
#1 Posted : Saturday, 18 February 2017 10:21:13 AM(UTC)
bazza30555
Hi , what was the best HP output holden got out of the 253 V8. Cheers Baz.
Mr.Jones Offline
#2 Posted : Saturday, 18 February 2017 12:54:22 PM(UTC)
Mr.Jones
253 in the Hurricane was about 260hp, but production cars (off the top of my head) HT-Q 185hp gross, HJ 175, HX-Z 161, VC Blue was probably the best of the lot with dual exhaust 115kw(155hp)net.
I'm sure someone will correct any or all that I have wrong.
Voltaire
#3 Posted : Saturday, 18 February 2017 1:06:33 PM(UTC)
Hard question as you can't easily compare them. The early engines are properly rated with an on-dyno gross hp in controlled conditions, but the later stuff is all net and the figures are almost useless to compare to early stuff. So for regular production 253/4.2 in a GMH vehicle it is hard to say. Here are the figures (only high comp, left out low comp):
Gross figures (SAE):
HT-HQ 185hp@4400rpm
HJ/LH 175hp@4800rpm
HX-HZ/LX 161hp@4550rpm
Net figures (DIN) single exhaust [dual exhaust]:
VB 87kW@4000rpm [96kW@4400rpm]
WB/VB-VH 100kW@4200rpm [115kW@4400rpm]
Looking at the above I guess you'd try to compare the VB figures with the HX-HZ engine (same engine) and then work backwards to guess a comparable figure for the blue 4.2 to put it up against the HT-HQ engine. My money would be on the blue 4.2 in this case.
If we are looking at non regular production engines then the Hurricane's engine was a good one as it was from memory a 4BBL engine, and the HDT VH GroupII and GroupIII 4.2L engine was rated at 152.9kW DIN which is a pretty decent 253.
castellan Offline
#4 Posted : Saturday, 18 February 2017 1:58:31 PM(UTC)
castellan
I don't think that the HDT 4.2L was rated in DIN
153KW = 205HP
100KW = 134HP DIN so in SAE who knows.
115KW = 154HP DIN
#5 Posted : Saturday, 18 February 2017 2:23:12 PM(UTC)
I think it is as their 5.0L engines were. Remember why DIN is not good is because it is affected by exhaust, air cleaner etc. HDT improved all of this.
castellan Offline
#6 Posted : Sunday, 19 February 2017 11:55:57 AM(UTC)
castellan
Come on, now how would you know that a twin exhaust made more power then, not to mention how much.
Any road if HDT were DIN we would truly know the facts of the matter then.
Non of Brock HDT were DIN, how could he have the ability to test that, maybe it's a Net KW rating.
A mate has had a VC Brock form 1986 and boy was it a slug back then and it still is.
#7 Posted : Sunday, 19 February 2017 12:53:42 PM(UTC)
When comparing engines no-one cares about what a dual exhaust does, you simply cannot compare engines if they are not all tested the same way, which is why DIN is totally useless for engine comparisons. Always has been, always will be! It was changed to DIN so people could compare vehicles, but that is not what is of interest here.
A VH GroupIII 5.0L (V5H) put out just under 200hp at the rear wheels, which is just under 300hp at the engine in SAE Gross terms. This is about 225kW SAE Gross. It is possible that the rated 180kW is SAE net (called the GM20 test from memory), but i'd not be banking on it as a done deal, we just don't know. Whatever it is the 4.2L 152.9kW will be the same rating method as the 180kW 5.0L engine.
castellan Offline
#8 Posted : Tuesday, 21 February 2017 10:49:11 PM(UTC)
castellan
I have a hard time believing that the VC Brock was 160KW DIN.
It just has big valves and extractors and the rest does not add much at all there is no mod to the cam.
It's a fair size cam in the 177KW and with big valve heads it becomes 184KW.
A VL with twin exhaust only makes 137KW with big valves, but with cat and unleaded and a bit lower comp. this is much the same as the VC Brock engine as one could get.
#9 Posted : Wednesday, 22 February 2017 5:02:33 AM(UTC)
Remember DIN is as installed and is drastically skewed by external factors like exhaust, air cleaner etc. You have a stock 9.2:1 blue 308 that isn't very different to a HT-HQ 308 other than 0.2:1 increase, a far better camshaft for the engine plus a non-optimal tune due to pollution requirements. The HQ made claimed 240hp/180kW SAE gross and the WB made 126kW DIN with dual exhaust. You'll pickup about 5-10kW with a decent air cleaner and a proper tune on that DIN figure. Then change the exhaust inc extractors, bigger air intake aircleaner, open the intake ports up and bigger valves, make the intake flow like a Performer (which is what HDT did), change the carb's tune and regraph the dizzy. That is an easy 34kW. If it wasn't DIN and was SAE net then what was the point, as 160kW SAE net would be about 130kW DIN?
castellan Offline
#10 Posted : Wednesday, 22 February 2017 9:59:19 AM(UTC)
castellan
I would not say that the cam is better than the HT-G-Q one at all, the reason for the HJ on cam is to pump more heat into the exhaust for burning fuel to lower the emissions mainly and more compression was only done so it works out the same volume efficiency.
Max Ellerys book how to rebuild and hotrod Holden V8, under camshafts says that the HT-G-Q cam is a better performance cam, page 144.
I would think that Net maybe 160KW and DIN around 150KW = 200hp a stock HT 308 GTS as claimed 203HP Net from South Africa.
So that would make the VC Brock more power than a HT 308 Monaro and the Brock does not perform as well as a HT GTS 308. maybe it's 160 SAE gross = 214HP.
126 TO 160 is like 26% more and we know that the most performance comes from the twin exhaust and 126KW has just that, extractors don't give as much performance increase as a twin exhaust do.
Putting extractors on a restricted exhaust does bugger all.
Look at the size of the cam in the 184KW only 24KW in that and it has everything that the VC Brock has.
Them VH Group 3 blows the VC Brock into the weeds.
#11 Posted : Wednesday, 22 February 2017 11:41:43 AM(UTC)
Rot! A HJ onwards cam is streets ahead in all areas! A simple look at the timing says it all. As does the original GMH dyno curves for the HT-HQ 308, it tops out at about 225hp or thereabouts. That engine is a joke compared to the HJ engine.
A Holden dual exhaust and pollution manifolds with the thermal switch is a HUGE impediment compared to a decent exhaust and extractors.
Edit. Here is the cam timing published by GMH. Duration is I think at 0.006" lift:
HT-HJ 253 cam:
27 BTC
63 ABC
270deg
71 BBC
19 ATC
270deg
46deg overlap
0.400" lift
HT-HQ was the same cam but retarded 5deg. This is probably one of the reasons they didn't rev. So timing is:
32
58
270
76
14
270
HJ-VL cam is significantly bigger and is degreed at zero using the 253's cam gear, plus you have to remember that whilst this exact grind was used in all SBC hydraulic applications at the time other than L79 and L46, these only had 1.5 ratio rockers, the GMH engine is 1.60:1. Specs are:
28
72
280
78
30
288
58deg overlap
0.400" lift
That is a whole 10deg inlet duration and 18deg exhaust. Inlet valve is open 14deg later, and exhaust closes 16deg later. Inlet and exhaust opening is similar.
Plus the HJ 308 has the added advantage of L34 compression HJ had 9.7:1, L34 9.8:1.
HJ 308 had exactly the same emissions requirements as HQ, same engine externally including the carby. Emissions changed around 8/73 during HQ which is when the 70412 carbs were replaced with 70432. 1/75 was only a canister.
Norm Darwin put all the good stuff in his Torana tough book. Original GMH dyno plots for the HT-HQ 308 show 226hp(126kW)@4800rpm gross and 160hp(119kW)@3700rpm net, and the engine is running out of breath at 4800rpm, in the "as-installed" net test it starts to choke at 3700rpm . He also shows Redco got 190hp@4100rpm for the standard 308 on its dyno, and the L34 engine put out 270hp@4900rpm. Remember that L34 engine still uses the same cam as the HQ but has better heads and exhaust manifolds, opened up intake and higher compression. That is 80hp (60kW) improvement from the dead stock HQ 308 to the L34 engine in SAE gross terms, so it is not hard at all to believe the stock blue 308 at 126kW DIN goes to 160kW DIN (34kW improvement) with the same basic mods other than the increased compression. Noting that the improvement of 34kW DIN versus the 60kW will probably largely be due to the 160kW DIN still pushing through an exhaust more restrictive than the dyno exhaust from the Redco tests.
Edited by user Wednesday, 22 February 2017 6:01:31 PM(UTC)  | Reason: Not specified
castellan Offline
#12 Posted : Thursday, 23 February 2017 11:52:19 AM(UTC)
castellan
HT-HJ 253 cam:
27 BTC
63 ABC
270deg
71 BBC
19 ATC
270deg
46deg overlap
0.400" lift
32
58
270
76
14
270
28
72
280
78
30
288
58deg overlap
0.400" lift
190HP@4100 std 308 what Dyno RW HP or FW HP
L34 what one ? the one with the cam that came in the box must be the 270HP @4900 it must be and not the std cam the L34 comes with that you are on about and that std cam used the 253 timing gear, and it's been proven in test that this L34 does not perform much better then a L31.
It takes a bit of work to get 270HP out of a 308 and no stock cam will do 270HP regardless of heads.
Here look VK 177KW @4700 = 237HP big cam and std heads
And VK 184KW @4700 = 246HP is the same engine only with L34 valves
270HP would be right for that L34 cam in the box they came with.
I was on about the Commodores single VS twin exhaust stock ADR and all.
The HJ 308 can not make any more real life compression than the HT-Q can, it's only static compression that was raised due to the new ADR pollution cam HJ on.
When you put a bigger cam in a engine one should increase the static compression due to the loss that happens in the real world of a running engine or the true compression will drop, and that why Holden did raise the static comp as such, look at the exhaust spec, see that increase is due to ADR it's to raise more heat in the exhaust to burn off more un burnt fuel.
The cam spec does not show all the details totally as one cam may be 20 - 60 say and all and another cam points out the same but they are not the same at all, if one looks at the whole spec totally.
Maybe the HJ 308 does make more power over the HT-Q as the SAE says 10HP, But that book says to use the HT-Q cam for best results.
Mods to the intake would only be improvement to top end rev and a VC Brock max KW is only at 4500RPM hardly any restriction at that but may improve performance from rev on wards.
#13 Posted : Thursday, 23 February 2017 12:45:14 PM(UTC)
It doesn't matter what the Redco curves are (it is an engine dyno), it is the increase from 190hp stock to 270hp that matters. There was only one L34, as GMH assembled them. However Redco also dynoed the L34 engine with the aftermarket HO kit on the same dyno and it is plotted on the same curve, it was 320hp (can't remember the rpm). They also plotted the F5000 engine. That is how it is, doesn't matter whether you choose to accept it or not! Redco did a LOT of development on these engines, and the 270hp out of the L34 is what they got. It has not been proven the L34 engine does not perform much better than a stock HQ L31. Redco proved otherwise. GMH simply hid the facts by only having the 2.78:1 rear axled cars with D70 14" tyres tested, with the restrictive standard Torana pea shooter tailpipes and mufflers (1.7" or something like that). The engine itself is a different story.
VK 177kW is the V5H engine. It is a standard cam (as in the HJ onwards cam) with big valve heads, better intake. This is the optional GroupIII 5.0L engine, same engine in VH was 180kW. The standard VK 308 is 126kW, same as blue 308. Again these figures are DIN so useless to compare, but the comparison between the stock black 308 and the V5H engine is almost the identical comparison between the stock HQ 308 and the L34 308, almost the same exact mods except for compression ratio. The black engines have the advantage of the superior camshaft.
270hp IS NOT correct for the HO kit camshaft, these were 320hp on the same engine dyno that the stock 308 put out 190hp.
The HJ cam IS NOT a pollution cam. It is a higher performance camshaft. If it was a pollution cam then it WOULD NOT have been used in SBC's from 1967 through to 1974 for compression ratios varying between 8.5:1 (1967 327/240) through to 10.25:1 (1969-70 L48 350/300)) and WOULD NOT have continued into the 1971-4 smog engines that had the same power robbing crap and tune on them as happened to HX 308. It is simple: THE HJ camshaft is a superior and higher performance camshaft, used from HJ (the highest performance standard pre-pollution 308) right through to the VL engine.
SAE claimed says 10hp, it is more like 25hp. GMH dyno curves show quite clearly 226hp@4800 SAE gross for the HQ 308 and 160hp (119kW)@3700 DIN. The 250hp@5000rpm for the HJ engine is probably telling the real story. Simply driving both gives it up pretty well. The only known road test that I know of for an un-encumbered HT-HQ 308 manual (ie something with dual exhaust and a manual transmission) was of John Bagshaw's Premier sedan (SS concept). It was slow as a wet week, and from memory only managed a top speed of not much over 110mph. There is a road test of a HJ GTS sedan with 5.0L and dual exhaust that shows how much quicker that the car was with that engine. Other than those road tests of dual exhaust 308 manuals in the day were rare.
I would put zero faith in anything published by Ellery. It is probably a typo.
VC HDT 160kW figure may not actually be the top rpm, it may well be a bit of advertising fiddle, just like the L34 claimed power of 240hp@4800. Those figures may well be true, but don't tell the whole story, like the L34 continues to make power up to 270hp whereas the stock 308 falls away. The HDT engine may well be the same, as the similar engine in a VH was rated as 180kW at 4750rpm.
Edit, L34 with HO kit got 320hp@5500rpm. F5000 engine got 490hp@7500rpm. On the same dyno that showed 190hp for the stock HQ 308 and 270hp for the stock L34.
Also GMH got as DIN 167hp (125kW) dual exhaust out of the ADR27A red 9.4:1 308. This was published as SAE gross 216hp (161kW) for the 9.7:1 version. This is as close as I can get on these too for comparison figures.
Edited by user Thursday, 23 February 2017 3:58:18 PM(UTC)  | Reason: Not specified
#14 Posted : Thursday, 23 February 2017 5:42:26 PM(UTC)
There was one publication around that incorrectly listed the VA prefix VK 304 (auto only applications) as 177kw, when it was nowhere near that, as it only had small valve heads on it - and was basically identical in spec to a standard VT prefix, automatic spec VK 308 that preceded it - all it lost was 4 cubes. In the later part of 85 it gained a few nice internals, but never got big valve heads, unless it happened to be in a car that went to HDT, then it had the heads changed over.
Manual VKs on the other hand - many of them had the big valve heads in the 134, 234 & 334 packs - regular Commodores, and they had 177kw (on paper).
Not only were the figures for comparison purposes somewhat dubious by using different measuring methods, you really can't compare the hp/kw rating of them, as the torque is a big factor, and this was not as dramatically different in the mid 80s as the hp/kw variances were.
On paper, the 137kw VL Group A is 2/3 the power of a 198kw VK Group A, but it's no slouch in comparison. In fact, there's very little difference in the actual performance of the cars - the VK only having that bit extra - certainly not some 60kw more. Owning a V5H spec VH, and a VL Group A, they both perform equally well - you wouldn't pick the 40kw paper difference at all. If anything, the VL is a more flexible & revvy motor, probably because of the roller rockers & A9L spec.
Guys who dropped EFI 304s into VB-VLs will know how the performance from one of them is pretty much up there with the best of the "legal" carby variants fitted to those models, but on paper they only had 165kw (or 180/185 in HSV form) - but the 385/400Nm of torque is what got them moving.
castellan Offline
#15 Posted : Friday, 24 February 2017 2:08:54 PM(UTC)
castellan
I know a dude who had a blue VK Group A 4 speed I think he had a bigger exhaust fitted as an option it was 3 inch and then he bought the red Brock VL Group A 5 speed and he said the Blue had much more power, but the 5 speed worked well to make it perform well, I gave him a run on the highway with my stock 308 auto p van and I had him till he walked by in top end over 200KM/H due to the 5 speed.
castellan Offline
#16 Posted : Friday, 24 February 2017 3:39:12 PM(UTC)
castellan
Commodorenut you are right as to the big cam 308's my stock 308 could keep up to all the big cam 308's, say 1/4 mile and up to about 180KM/but then they would blow mine away.
It's all in the gearing and how far you rev it, makes a big difference, when one does not know how to get the best out of your performance.
If a dude drove a good stock well tuned 308 engine and pulled 5500RPM in every gear it's times will be crap, but if the only rev to 4500RPM that thing will drop 1/4 times and even if you go to low ratio diff it will be crappy because we are using the torque to do that work.
The big cam 308's need it to rev to perform, so the 1/4 times are not that much better, but 1000m you will see a big difference how that now performs over the stock cam.
So it's the gearing that makes the VL Group A perform so well, there is no point in rev past 4500 and you get to 180KM/H and drop it into 5th and she is back into to a sweet part of the power band again, but over 4500 in 4th it's out of the sweet power band.
Most people do not understand Power or Torque correctly.
castellan Offline
#17 Posted : Friday, 24 February 2017 4:55:49 PM(UTC)
castellan
I don't think that them LH twin exhaust were that restrictive aren't they the same as a HQ twin system.
The L34 came with a stock cam with 253 timing.
The HJ cam grind is exactly the same as the Chev cam spec, maybe it is, but is it 100 % truly the same. the cam is used in the ADR engines as well. why would the 253 go to a smaller cam in the HJ on then.
250HP HJ SAE
240HP HT-Q SAE
161HP HX-Z SAE I agree with Holden we have a HJ with 10HP over the HT-Q and that's bugger all, the HX-Z shows it's gutless with 40 to 50HP SAE less.
I don't think anyone is going to feel 10HP much at all.
I have for HQ 196HP dyno and HT-G at 203HP net by South Africa Holden GTS brochure.
Maybe you is right at 226HP net for the HJ.
Bagshaw's could of had a 3.55 diff maybe a 3.36 but the Australian performance testing back in them days were crappy, just as the power figures are backwards SAE crap, Holden and Ford were never open about the true Net HP but any road you could find Net figures in the F100's and it sure tells the true story of what you are going to get, take the Ford 302 Cleveland 250HP was the SAE and one 302 F100 were 134HP net for crying out loud and up to 203HP net.
I could imagine some bloke with a 302 XB Falcon who believes it's got 250HP and then he's got a same year 302 F100 Oh yes 250HP he will say, but some how the F100 is a slug and that XB and if he gave a 308 HQ a go he would not have a hope at all and it's rated at only 240HP, so you see what I am on about with SAE, it's just truly crap.
castellan Offline
#18 Posted : Saturday, 25 February 2017 3:45:32 PM(UTC)
castellan
If only we were as advanced as South Africa we would of had all the answers about the Net power of all the engines.
When looking at the single exhaust of the 5.0L WB VB-C-H-K-L and the single exhaust HT-G-Q-J-X-Z we see that the pipe on these are smaller, so power loss would be more so.
That South African HT GTS 308 is rated at 203HP net, maybe that single muffler with 4 tail pipes flowed better than a HQ twin exhaust.
The HZ 5.0L all came with twin exhaust but for ute and p van.
Motor Manual test Dec 1978 5.0L auto GTS with the crap T400 auto, did a test putting extractors and a better twin exhaust on it, I don't regard the power figures of the before as worthy much, because I don't think it was in a good state of tune before hand but the after could be of some regard, still bloody gutless tho.
2000RPM before 65HP after 77HP
2500RPM 77 - 92
3000 89 - 107
3500 92 - 119
4000 90 - 121
4500 84HP-126HP
The times before and after read
0 to 60 KM/H in 5.6 sec after 4.5 sec
0 to 80 KM/H in 7.9 - 6.2
0 to 100 KM/H in 14.3 - 11.1 now that's gutless as a UC sunbird with the 1.9L moon glow 4sp manual in the same book did 0 to 100KM/H in 14.9 sec and how is this a WB 1983 Caprice with 2.60 diff ratio did 0 to 60 in 5.3 sec, 0 to 80 in 7.6 sec and 0 to 100 in 11.0 sec.
Here is a Dyno of Fly Wheel HP of a stock HQ 308 regarding street machine workshop series number one.
2500RPM 138HP
3000RPM 164HP
3500RMP 187HP
4000RPM 193HP
4500RPM 188HP
#19 Posted : Sunday, 26 February 2017 8:58:02 AM(UTC)
250HP HJ SAE
240HP HT-Q SAE
LH V8 exhaust were very restrictive, the tailpipe and muffler(s) were 1 5/8" for both single and twin system. This is why the 308 on an LH Torana always got a twin system as the tiny little single system was too small. HQ single had 1.75" tailpipe and muffler which is why they got away with a single system on 308 and also on 350 auto outside GTS. HQ twin systems were 2" tailpipes but afaik used a stepdown to 1.75" mufflers.
Yes I know L34 had a stock cam, I told you that.
Yes the HJ cam is identical to the SBC grind, same lobe centres, same overlap etc. The only difference is the peak lift, it is smaller on the HJ as the 308 uses a 1.6:1 rocker, SBC is 1.5. The cam lift is ground to get the same valve lift with the different rockers as the 308 uses the same springs as a SBC for the same cam, same installed and compressed heights. The 308 didn't suffer too bad from pollution equipment most likely due to the Quadrajet, they kept fiddling with the 253 to make it pass emissions. The only really bad 308 was the HX, but it was never as bad as the HX 253. I think they got the intake manifold badly wrong on the HX, they revised it drastically for HZ and then dropped the 308's compression mid 1978 from 9.7 to 9.4. It never copped as much criticism as the 4.2 but it was down on peak power compared to the HJ engine. Internal GMH dyno tests show the HX 308 has similar peak power to the HQ engine but it never delivered as well "in-car", probably due to all the power and driveability robbing stuff on it like the exhaust flap in the passenger side exhaust, spark advance control in lower gears etc.
HT-HQ 240hp is an advertised claim, original GMH dyno charts show 226hp. The 250hp of the HJ is far closer to real and the engine revs out further as a result of the cam and higher compression. Peak power is delivered at higher rpm.
It is a 3.36 rear axle in that concept SS car, wearing polycast rims and ER70H14 tyres.
You at right that the advertised figures are not truthful, but I never use them, only use figures off internal Engineering documentation, and most show dyno curves.
castellan Offline
#20 Posted : Sunday, 26 February 2017 1:09:38 PM(UTC)
castellan
Looking at the HT 308 single exhaust it looks more restrictive to me than the HQ single exhaust.
I believe the HK 307 single exhaust to be a little less restrictive, when the HT came about it was all about how quiet the new car was that was pushed.
The GTS twin exhaust HK-T-G if I remember correctly made more noise than the HQ twin exhaust, so I would say it flowed better as the HQ was quite as.
Remembering back a mate had a real good nick stock HQ GTS 308 auto with 3.08 diff with the original twin exhaust, now the performance of that was better than a VC Brock.
Every stock 308 with a 3.08 diff that I had or drove would valve bounce at 200KM/H 5000RPM.
I never seen any ADR27A 308 that ever could be said it performed well to a pre ADR27A, the VC Brock was a slug the CH-K Group 3 were better performing than the VC Brock and the VK Group A performed better again but were restricted by ADR.
We know that the EGR does not open when your flat to the boards in top gear as well there is nothing to stop it making more power then a pre EGR 308, but it still sure does not perform well at all, so why not ?
The 308 HX intake manifold and the HZ VB is nothing.
I had stock HQ intake manifold type pull over 300HP and at 6500RPM still making more power and the only intake I thought any good was the performer, the torquer was total crap on a road engine.
I know some people love the big intakes but I have never seen them work well on street engines but all have been total gutless failures.
People talk about max power rating, that's crap, a graph is much better to explain the facts, a HX intake will not make any loss in any performance at all at 1000RPM or 2000 or 3000 or 4000RPM do you agree with that or do you think that the lack of power is due to this restriction, The ADR27A just dose not perform at all, be it 1000 or 2000 or 3000RPM etc
That cam gear timing must be retarded more than the HJ 308, I believe it has to be the problem as it restricts the flow on the valve opining when the piston goes down, I did this experiment with my 308 with a 20/60 cam I had, I retarded it 6 deg thinking I may get a bit more power up top, but all it did was destroy power everywhere it killed it just like a ADR27A would. so I found out to only fiddle with cams above 35/75 say to try improve some point in the rev range.
I found that jetting can make a hell of a lot of difference as well on power all through the rev range as well and that big CFM carby's are mainly nonsense as well.
My HX intake did feed my 20/60 cam L34 head 308 auto to 213KM/H at 5300RPM
3 Pages123>
This page was generated in 0.360 seconds.
