Looking for a 7029283 quadrajet !! Any help Byron ??
So you are after a later HK GTS327 carby? |
Unless it is one of the first built you don't want that carby. |
Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
Cmon guys...Just getting interesting!!!
"HOLDEN MONARO. OUT TO DRIVE YOU WILD!" |
yes it is Silverfox . dont know what happened !
Joined: 23/07/2016(UTC) Posts: 20 Location: adelaide Thanks: 12 times Was thanked: 2 time(s) in 2 post(s)
I thought the HT would have the 29283 carb does that sound right ??
Most do. Really early ones used the later HK carb 7029283. To date we have only ever found 4 x distinct date codes on 29283 carbs for all of HT-HG, and one of those has no broadcast sheet code. I have a hunch there may be one more not yet found. Also only found 1 date code so far on 29284 and 1 on 7029284. |
