#1 Posted : Friday, 12 May 2017 1:56:20 AM(UTC)
got the ventilation system out of the vk, but the numbers have fallen off the vacuum hoses to the control behind the dash so can't identify where they go. Does anyone have any idea which nipple the main vacuum hose goes on, if I can identify that I hope to match up the others by process of elimination.
thanks
#2 Posted : Friday, 12 May 2017 6:24:03 AM(UTC)
Main vac feed goes to #4 from memory. There are very small numbers moulded into the plastic beside each port.
#3 Posted : Saturday, 13 May 2017 2:21:40 AM(UTC)
Thanks Mick to the rescue again! I knew about the numbers on the distribution block just not where they went. been driving me mad for weeks.tried running air thru them to see where it came out but no success.
