#1 Posted : Sunday, 28 May 2017 6:55:36 PM(UTC)
Anyone have access to one of these with original carby?
Looking for the carb's date code. Carb will be a 7043284 and date code will be 1xx4 or 2xx4.
The earliest 1/75 onwards carby I have is 2304 which is probably the 1/75 carb's first date code.
It is hard to know the last date code used on a local Holden, Statesman or Torana as this 1974 spec carb was used on export (inc local Consulate) cars and marine applications, and as a result I have found these with date codes as late as 1979.
Any help much appreciated. You'll pick these cars by lack of canister and vapour line, but will still have space in the plastic clips under the car for the vapour line.
