Joined: 2/02/2009(UTC) Posts: 562 Location: On a build over WWII airfield. Got the .50 cal cases from my driveway to prove it Thanks: 30 times Was thanked: 8 time(s) in 8 post(s)
Any thoughts about fire extingushers? I'd like to have one in mounted in the car,just in case. Powder or CO2? Powder is messy and gets everywhere, on the other hand the "lets get the fire out, then worry about the clean up" idea is practical thinking. What are you guys using?
Cheers, Chris |
Attn camry drivers. The accelerator is the skinny pedal on the right. |
Powder. I don't think you'll get a CO2 one small enough. |
Joined: 21/04/2017(UTC) Posts: 293 Location: Tolmie Thanks: 2 times Was thanked: 24 time(s) in 24 post(s)
both will do the job as far as fuel and electrical so the most practical would be the one that fits the space you have available.
Thanks: 5 times Was thanked: 12 time(s) in 10 post(s)
PSA:
Powder type will clump and settle over time, it would not be much fun to try and put out a fire and hear pressure escaping and not much powder.
Tap it with a rubber mallet while rolling it around on the bench every so often, every 3 months is a good idea.
