KBM Offline
#1 Posted : Friday, 9 June 2017 7:40:43 PM(UTC)
KBM
i'm doing up a hk panel van and having trouble getting a rear drain tube to fit.
your DT1000A drain tube has a bend in it that doesn't fit with the straight tube I removed.
the DT1000 tube for the ej/h s/w is straight but nearly twice the length as what is needed. although it is the right fit at the top
I've searched my "the first 20 production years" catalogue as well as the hk/t/g catalogue and found these
7417364 ej/h s/w -dt1000
7417443 ej/h hd/r ute
7420411 hd/r p/v
7435633 hk/t/g p/v, same as removed from my p/v
7417443 hk/t/g ute ? I've never seen a drain hole in the back of any hk ute I've owned.
I don't know about the ej/h p/v drain tube because my reference catalogues don't list a number
but the DT1000A certainly doesn't fit my hk panel van and I know of no drain tube of this era that has a bend in it.
where does the DT1000A fit in and do you make a drain tube that will fit my hk panel van?
Edan Offline
#2 Posted : Thursday, 15 June 2017 4:15:27 PM(UTC)
Edan
Below are some of the drain tubes we produce
DT1000 DRAIN TUBE REAR CROSS BAR EJ EH WAGON = 7417364
DT1000A DRAIN TUBE REAR TRAY EJ EH VAN = 7418322
CVDT2 COWL VENT DRAIN TUBE FB-HR = 7412594
CVDT3 COWL VENT DRAIN HK HT HG = 7433004
I don't believe we produce the exact drain tube to fit a HK HT HG Van which is #7435633
Regards
Edan
RARE SPARES
KBM Offline
#3 Posted : Thursday, 15 June 2017 7:37:48 PM(UTC)
KBM
thanks for the info but why is the DT1000A advertised in your listings as fitting the HK HT HG van when it doesn't.
