Thanks: 11 times Was thanked: 11 time(s) in 9 post(s)
Can running a 6 cylinder coil on a V8 cause any problems?
Originally Posted by: LS350 Can running a 6 cylinder coil on a V8 cause any problems? I assume we are talking about ignition coils here ? If so, what type of 6-cyl coil & what V8. I sell ignition coils to the trade & currently catalogue over 520 different types, not counting different branding, so it does matter. Dr Terry |
It is a 1970 Lucas coil 8C12 stamped on it but has a 6 cylinder part number on it. The 8C12 also was used on V8's but has a different part number.What will happen Dr Terry if I use the wrong one on a V8(350)?Can you modify the coil to suit ?
Those two ignition coils are very similar. Their primary resistance is virtually the same & are both designed to work with the factory Holden ballast (in the wiring harness) & a good old fashioned points distributor. The modern Bosch equivalent is the SU12R which they list to fit all Holden, Falcons & Valiants, both 6 & V8, of that era. Dr Terry Edited by user Monday, 12 June 2017 1:34:01 PM(UTC)
| Reason: Spelling |
Thanks Dr Terry for your help I am running the old points system with a delco dissy (old school) and the information you provided was greatly appreciated.
