BIGRAT454 Offline
#1 Posted : Thursday, 22 June 2017 11:37:50 AM(UTC)
BIGRAT454
Hello
I am seeking info about the original factory air gap on V8 Monaro ht ht kg
Fuel tank to pipes exhaust
Was there a heat shield and what was the actual gap please
And thank you
gm5735 Offline
#2 Posted : Thursday, 22 June 2017 1:12:33 PM(UTC)
gm5735
Do you mean between the tank sides and the inner "chassis rail" and shock absorber? If so, the answer is not much. Around 20mm at the closest point for a factory system.
There are no heat shields on the tank, only a transverse heat shield under the boot floor above the transverse rear muffler. The heatshield was fitted to 186S cars and all V8 cars, with the exception of early HK, which were the subject of a recall.
BIGRAT454 on 22/06/2017(UTC)
BIGRAT454 Offline
#3 Posted : Thursday, 22 June 2017 1:20:00 PM(UTC)
BIGRAT454
Hello
I'm a girl and new to this so I'll do my best
The fuel tank as in the car
The dumpers come out the end and then the stainless exhaust runs close to the fuel tank
From factory Monaro
What was the gap or air gap between the two parts
My issue is a pit inspection at which time they are saying the gap needs to be 100mm
When a 2011 standard VE Ss V8 has a plastic fuel tank and a gap of 42mm between its muffler exhaust pipes and the tank.
If I could figure out how on earth to attach a photo then it would be easier to understand
Sorry and thank you
Gerard Offline
#4 Posted : Thursday, 22 June 2017 5:15:20 PM(UTC)
Gerard
Have a look at a previous topic "327 and 350 original exhaust systems" I added some photos there earlier this year and the third last one is probably the one you are referring to
Regards Gerard
BIGRAT454 Offline
#5 Posted : Thursday, 22 June 2017 5:53:22 PM(UTC)
BIGRAT454
Thank you I don't know how to navigate this forum
I shall try thank you
#6 Posted : Sunday, 25 June 2017 6:22:59 PM(UTC)
Nowhere near 100mm I reckon.
A few exhaust photos here:
http://www.fastlane.com....al-exhaust-systems.aspx
and here:
http://www.fastlane.com....7-tailshaft-colour.aspx
"I would never want to be a member of a group whose symbol was a guy nailed to two pieces of wood" (George Carlin)
This page was generated in 0.165 seconds.
