Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
Hi If Vin numbers were allocated when orders were taken I gather J1 42215 was ordered well before J1 50367. Were HK chassis numbers stamped in sequence like the Vin numbers ie didn't matter what model. Were HK Monaro's body number in sequence ie a 80337 could have followed a 81837. Cheers John.
It all depends upon the assembly plant. Some allocated the PSN at the end of the assembly process, others allocated it when the vehicle was added to the schedule. J142215 was entered into the schedule before J150367, however this doesn't mean the earlier PSN vehicle was finished before the later one. One good example is my Acacia Ridge Picardy red GTS327, body exited the body plant in August but the vehicle wasn't assembled until October as Acacia Ridge missed out on a batch of GTS327 engines (the May 1968 assembled engines). It had to wait until the July 1968 batch got here. So it has PSN, BODY and chassis numbers consistent with mid August production but it wasn't assembled until October 1968, and its GMH engine number is consistent with October 1968 307's from Acacia Ridge. Body numbers also depend upon the body plant. Some used a sequence for each model, others were a cumulative total for the series or for all vehicles from that body plant, and it changed depending upon when in time we are talking about (like HK is different to early HQ etc). Edited by user Thursday, 31 August 2017 8:25:26 PM(UTC)
| Reason: Not specified |
J142215 is the white with black vinyl roof monaro on Muscle Car Sales and had a delivery date of 11-3-69, J150367 is mine with delivery date of 24-12-68 and when I seen the vin, body no and chassis no all way earlier than mine I though maybe no one wanted a 80337 186 and it had been sitting around for awhile
The 337 was probably a stock order, yours may have been a retail order. I have heard of initial build HK V8 337's (June 1968 build) being sold new in 1969. By that time the car will have sat around (probably outside) for over 6 months with original fluids, Their engine and box were 18 months old by that time too. |
You wouldn't have been happy if you had known your 337 v8 had been sitting outside all winter before you purchased it. People now days trying to find the build date would be scratching their head when their 69 monaro is actually a 68
Yes, once compliance dates came in 1/70 this problem went away. It was quite possible that someone could have bought say a Pagewood GTS from initial production at Monaro release. At HK runout mid 1969 around HT release there would still have been the odd early HK Monaro still not sold, built before the GTS. Imagine your next door neighbour bringing their new Monaro home, obtained maybe 8 months after your GTS. You look at the chassis number and say "it was built before mine!" |
Great information HK as so called monaro experts would tell the owner of the white car his owner manual is fake as its to early to be a 69. If l ever sell my GTS v8 we have talked about l'll get told it should have a salisbury not a banjo.
