benny Offline
#1 Posted : Thursday, October 19, 2017 1:19:49 PM(UTC)
benny
wondering if one of you guru,s can tell me what type of starter motor I would need for a ht 350 manual October 69 81837 car... have been told the earlier one with the alloy nose was replaced by a cast iron nose delco remy, but am unsure.. thanks..
#2 Posted : Thursday, October 19, 2017 3:16:00 PM(UTC)
350 had 11" flywheel so it isn't the same as a 327, from a Holden or other GMH assembled car anyway.
benny Offline
#3 Posted : Thursday, October 19, 2017 3:49:12 PM(UTC)
benny
so does that mean it ran a special starter that's hard to get or is it the same on us cars running a 350, trying to get everything on this car correct.thanks again..
#4 Posted : Thursday, October 19, 2017 3:57:17 PM(UTC)
Dunno, everything else on the engine is standard Tonawanda L48 other than one exhaust manifold, sump, carby and dizzy so I’d assume it is just a stock 1969 11” starter.
benny Offline
#5 Posted : Thursday, October 19, 2017 4:11:17 PM(UTC)
benny
ok, had a lot of trouble finding a carby and alternater, so was wondering if there was a special part number for starter as well, thanks so much for your help..
gm5735 Offline
#6 Posted : Thursday, October 19, 2017 5:27:52 PM(UTC)
gm5735
Our engines got a higher torque starter motor after hot starting problems in the US with early L48 engines with the 168 tooth flywheel. I'd expect to find a 1108418 numbered starter in an original car of that vintage, although others are possible. It has a cast iron nose.
#7 Posted : Thursday, October 19, 2017 5:58:46 PM(UTC)
Early L48 was 9/66 so going by what Geoff says above you’d think they’d have worked out by the start of 1969 that the higher torque units were available. A look at SS Camaro may help too.
gm5735 Offline
#8 Posted : Thursday, October 19, 2017 6:23:15 PM(UTC)
gm5735
What I should have said was early in the 1969 model year. The Chevrolet service bulletin is dated Dec 1968.
#9 Posted : Thursday, October 19, 2017 6:25:59 PM(UTC)
Makes more sense! Took them a while though to work it out though.
