nineteenfortyeight Offline
#1 Posted : Wednesday, 15 November 2017 8:49:50 AM(UTC)
nineteenfortyeight
I have a dash assembly which is a horizontal style. It is a flexidrive instruments dash. It shows the 200k speedo on the drivers side and from the left it has a clock, oil and fuel gauge. The knob is missing off the clock but the pin/adjuster is intact.The needles are white. It has a part number: GM 9932418. 42,516 is showing on the odometer. And the wiring is still on the back too.
Any clues as to what model it is from?. If it is after HG I am lost....... Sorry but I do not have a pic for you to look at?
Ron
48 215
#2 Posted : Wednesday, 15 November 2017 9:53:42 AM(UTC)
Sounds like HJ Premier, but what about a temp gauge.
#3 Posted : Wednesday, 15 November 2017 10:45:21 AM(UTC)
nineteenfortyeight
Thanks Dr Terry. The second gauge is the temperature. I should have turned on the light! Oil Light must be below the speedo.
Ron
48 215
This page was generated in 0.276 seconds.
