griffo Offline
#1 Posted : Thursday, November 23, 2017 7:00:41 PM(UTC)
griffo
Hi Fellas....Here is the sonerio....I am putting a V8 in a WB ute that had a 6 Manual...
The pedals are different with a longer hook, on the V8's that is pivoted in the bottom hole from what I can gather..(the top hole for 6's)
Now the issue is.....Is there a easy way of taking out the pivot bolt thru the pedal without having to take all the brake structure off,to course the bolt slides out to the right not the left where it would be dead easy and make sense?
I plan to extent the hook 25mm plus relocate the flat part of the pedal higher by 50mm or what ever it needs to be equal with the brake length.I'd buy one but can't find one for love nor money.
I have a UC Torana cable that is 50mm shorter...the travel in inner cable is longer ....any use?
Thanks of course....Griff
Mods...This may belong in the tech forum ...sorry.
Edited by user Thursday, November 23, 2017 7:02:10 PM(UTC)  | Reason: Not specified
#2 Posted : Thursday, November 23, 2017 7:28:45 PM(UTC)
From memory you have to release the master cylinder to move the brake pedal so the bolt slides out.
V8 WB pedal and cable is easy to find:
https://m.ebay.com.au/it...5b392:g:5ecAAOSwvR5Z6Coq
griffo on 11/23/2017(UTC)
KBM Offline
#3 Posted : Thursday, November 23, 2017 7:39:03 PM(UTC)
KBM
Haven't owned a WB in a while but have an original manual. Hope these help.
sorry about the one upside down i'm new at this photo stuff.
No mention of different hook length in manual.
Edited by user Thursday, November 23, 2017 7:42:53 PM(UTC)  | Reason: Not specified
 1 user thanked KBM for this useful post.
griffo Offline
#4 Posted : Friday, November 24, 2017 1:37:40 PM(UTC)
griffo
What a PITA..
I am suicidal......laying upside down under a dash at my age!!Cursing Mad Cursing
I am over and off to the PUB.
KBM Offline
#5 Posted : Friday, November 24, 2017 7:34:16 PM(UTC)
KBM
Mate, have a good sip at the pub and come back to it tomorrow when your fresh. The amount of times i've gone to do a two minute job and near on caused a world war 'cause the bloody thing wont fit as it should only to find out that after a "time out" the bloody thing fits easy next time. The better half can usually hear me from the back paddock.
#6 Posted : Friday, November 24, 2017 8:10:54 PM(UTC)
Hmm, try greasing the uni drive joint in a 743B Bobcat! Worst job I have ever had to do on a piece of machinery!
KBM Offline
#7 Posted : Friday, November 24, 2017 9:11:59 PM(UTC)
KBM
Just a thought but I've found a small fluro light works heaps better than a torch when working under the dash. you can see heaps better but unfortunately it doesn't help with the pain in the back.
griffo Offline
#8 Posted : Saturday, November 25, 2017 6:39:38 AM(UTC)
griffo
I feel worse..LOL!....I drank and slept on it.
I have a idea...If I crack a wheel cylinder bleeder the brake pedal should go to the floor ...right?d'oh!
Then I should be able to slide the bloody clutch bolt out to the right hand side....yes,no ...thoughts?
Do the job on the pedal then put it back in the lower hole as per V8's.Boys that should save me a hell of a lot of frustration.Dancing
Gee that sounds good tho ...YAY,,LOL,
Oily Offline
#9 Posted : Saturday, November 25, 2017 6:49:08 AM(UTC)
Oily
Morning. Griffo you could try just taking the two nuts off the master cylinder. Oily
griffo Offline
#10 Posted : Saturday, November 25, 2017 8:11:09 AM(UTC)
griffo
Morning Oily ol mate.............Ok then move the master cylinder forward enough so the pedal then will drop to the floor..I mean how easy is that!
HK already told me that but my addled brain just thought he meant the booster and all....pass me a gun.Brick wall
Mate i owe you guys beer or 3...Yay...love ya like brother ol son..LOL.
Edited by user Saturday, November 25, 2017 8:45:29 AM(UTC)  | Reason: Not specified
#11 Posted : Saturday, November 25, 2017 10:04:29 AM(UTC)
I actually meant disconnect the pedal from the booster, which may give you enough movement in the pedal. If not remove the brake pedal first to get to the clutch pedal.
griffo Offline
#12 Posted : Saturday, November 25, 2017 12:50:46 PM(UTC)
griffo
Thanks again HK and ol mates......I had to do that HK..ThumpUp
Job is now complete , the pedals are anyway.Dancing
I have had enough for one daySpeak to the hand ......I am going back to the PUB...stuff it.BigGrin
KBM Offline
#13 Posted : Saturday, November 25, 2017 3:29:14 PM(UTC)
KBM
Hey griffo The local pub must love it when you work on cars. Do they send the locals around with "quick fix" jobs to get you in the mood for a beer?BigGrin
#14 Posted : Saturday, November 25, 2017 5:28:08 PM(UTC)
The clutch cable used to fall off my brothers WB if you pulled the pedal upwards with your foot. It happened to me at the lights once. The fun bit was getting it back on.
Actually, it used to get stuck on flat out if pushed the accelerator all the way to the floor as well. That’s fun too when you don’t expect it, like when overtaking.
Edited by user Saturday, November 25, 2017 5:29:50 PM(UTC)  | Reason: Not specified
griffo Offline
#15 Posted : Sunday, November 26, 2017 9:08:25 AM(UTC)
griffo
Hi wbute....This clutch still had the little rubber ring thingy on the hook to stop that happening, when I tried to roll it out of the way it broke of course didn't [it angry] .
I don't have one to replace it so a cable tie will have to do...I remember the UC Torana I had would come off to like you say.....According to the book there was supposed to be a clip over the top of the hook to stop that happening...Poor design I think as they used to come off and got sucked up by the vac cleaner.
Edited by user Sunday, November 26, 2017 10:00:01 AM(UTC)  | Reason: Not specified
