Joined: 6/05/2016(UTC) Posts: 151 Location: SEQld Thanks: 11 times Was thanked: 3 time(s) in 3 post(s)
Hi again fellas...I have a cpl of quads i would like to know if they were off a blue 253 or red/blue 308.
I guess the diff would be the jetting, but would the ID numbers tell me? I have done a search but to no avail on how to tell one from the other externally.
Thnx...Griff
The secondary vacuum pull offs are the easiest way to differentiate an early red pollution from a blue motor one. Blue motor should have two metal encased diaphrams, red pollution type have a plastic or resin type very noticeable. Non pollution red motors used a "divorced choke" the coil heater was not attached to the carby directly it screws into the manifold so they are pretty obvious too. |
Another HQ SS |
Put up the numbers (or PM to me) off them and i'll tell you what they were off. If you don't have what you want I may be able to swap you. |
Thx for that HK... I got the spy glasses out and here are the numbers.... 17084596......1215...IRB 17059595......0250...CXK of course...Griff.
The CXK is VC-VH or WB 308.
The other you should send to me and i’ll send you whatever one you want except for GTS327/350 carb......Or list it on EBay for silly $. It is a VK Group A carby. |
Originally Posted by: HK1837 The CXK is VC-VH or WB 308.
The other you should send to me and i’ll send you whatever one you want except for GTS327/350 carb......Or list it on EBay for silly $. It is a VK Group A carby. Really!! I have no use for a Grp A carby...I picked it up off gumtree for under $100 if I remember correctly...I wanted some part off it that I later found so never touched it...I'll PM you when I get back from town ol mate.....I'll take some pics and send to you... Griff.
