Fastlane
Holden Forums
Holden Technical Talk
H KTG 4spd hydraulic clutch return spring length
Thanks: 50 times Was thanked: 6 time(s) in 6 post(s)
H All Anyone know the static length of the clutch fork to slave cylinder bracket return spring (hook end to hook end)on a hydraulic 4spd set-up in HKTG? I have two and one is a bit too short (90mm) and the other is a bit too long (140mm). Cheers Jacko
Doesn't answer the question but might help, they are the same part number for the two RHD 4spd manual applications: RH slave on a 307 & 327 and LH slave on HT-HG 350.
If one that you have is too short and the other too long just get one on between! |
Joined: 16/04/2014(UTC) Posts: 768 Location: Victoria Thanks: 1 times Was thanked: 49 time(s) in 47 post(s)
198mm inside loop to inside loop.
cool Geoff, thanks. This must be the 'in between one'.
Ian, I lied. The real answer is 75mm, at least with the fabricated clutch slave mounting bracket. Sorry about that.
Stretched the 90mm one and it seems to go OK.
Fastlane
Holden Forums
