Joined: 2/12/2017(UTC) Posts: 5 Location: Wambion nsw
Hi can any help workout these hg ute codes please bo108gr 43007-s
131-12a 563-13134
Some of those numbers don't look correct. Maybe the plate is badly stamped, damaged, corroded or just dirty.
The first 5 digits should be something like 80180, which is for a 6-cyl Belmont ute. Other ute numbers are 80280, 80380 or 80480, for V8 Belmont, 6-cyl Kingswood & V8 Kingswood, respectively.
The G refers to HG series & R = right hand drive.
563-13134 is Dulux code for Glacier White, which is unusual in an HG, where the 'normal' white is Kashmir White. Although having said that Glacier was available on fleet order.
The the first part of the TRIM number (131-12A) isn't correct either. 131 belongs to a two-tone paint scheme in FJ. A Glacier White HG should be TRIM prefix 1821.
The second part of the TRIM number (12A) refers to the interior which for this code should be Red.
Dr Terry |
Ok thanks The photo not real good it’s hard to read my eyes ain’t that good either I’ll have another look but it’s supposed to be a factory v8 I’ll check again with you info thank you
It’s from what I can make out 80180gh8 Does that make sense
Pagewood HG plates are hard to read, the 8’s especially. It is probably built during HQ passenger production hence the HQ white. |
Originally Posted by: HK1837 Pagewood HG plates are hard to read, the 8’s especially. It is probably built during HQ passenger production hence the HQ white. Yeah ok the 80180g From what I read 801 is a 6 cyl is that correct
0180 is 6cyl Belmont ute. If it was a V8 Belmont ute it'd be 0280. |
Originally Posted by: HK1837 0180 is 6cyl Belmont ute. If it was a V8 Belmont ute it'd be 0280. Awesome thanks for all your help
Thanks: 2 times Was thanked: 27 time(s) in 26 post(s)
Chassis number in firewall behind the engine should start AHG and end in an S.
Warren
