htprem Offline
#1 Posted : Monday, 15 January 2018 10:20:34 AM(UTC)
htprem
Hi All,
Does anybody know what a cable kickdown Trimatic with the code H V (definitely not H Y) would be out of?
I am guessing it is out of an HG or LC maybe?
Any advice would be appreciated.
htprem
#2 Posted : Monday, 15 January 2018 10:26:21 AM(UTC)
A Trimatic with an HV code is out of an HG 186-S with a T-bar console shift. It is unique in that it has the shifter on the LH side of the transmission.
htprem on 15/01/2018(UTC)
htprem Offline
#3 Posted : Monday, 15 January 2018 10:44:56 AM(UTC)
htprem
Hi Dr Terry,
Thanks for your advice.
I can see how the left hand side floor shift aspect of the transmission is unique, but am intrigued that you mention 186S - did the S motors have a slightly different transmission (well, internals) to the standard 186?
htprem
#4 Posted : Monday, 15 January 2018 11:42:50 AM(UTC)
Yes, they did. Each Trimatic is closely matched to each engine. For example in HQ the 173, 202, 253 & 308 transmissions were different to each other. The V8 ones obviously had a larger bell housing, but the valve bodies in each was tailored to match that particular engine's torque curve.
htprem Offline
#5 Posted : Monday, 15 January 2018 12:14:53 PM(UTC)
htprem
Hi Dr Terry,
interesting that Holden went to that sort of effort, given they scrimped elswhere - I am presuming the Powerglides are all the same except for 6 vs V8?
Would you happen to know the code for an HG 186 Floorshift Trimatic?
htprem
#6 Posted : Monday, 15 January 2018 1:37:03 PM(UTC)
An HG 186 floor shift Trimatic has the code HB. Don't get too concerned about the minor differences in calibration between the different Trimatics. Over the years a lot has changed, the clutch materials & fluids are much improved & the auto trade has vast experience in making these boxes work well.
AFAIK all HD-HT 6-cylinder Powerglides were the same except for the floor shift variety, which only differ in the shape of the selector lever. There are 2 distinct types of V8 Powerglides though. The ones which fits behind the 307-350 Small Block Chev V8s have a one-piece housing., whereas the HT 253/308 Powerglides are basically 6-cyl units with a unique bolt-on bell housing. Again each of those have either column shift or floor shift style levers on them.
Edited by user Monday, 15 January 2018 1:40:26 PM(UTC)  | Reason: Not specified
#7 Posted : Monday, 15 January 2018 1:55:12 PM(UTC)
Just to expand on Terry's info, the HT-HG 253/308 powerglides whilst being a 6cyl box with a unique bellhousing, also used the tail-housing from a 307/327/350 powerglide thus used a similar gearbox crossmember to the SBC box, and also used the LH side speedo cable and the SBC style crossover mechanism for the column shift examples. The 6cyl powerglides used a RH side speedo connection and shared the gearbox crossmember with a all syncro 3spd IRC
htprem Offline
#8 Posted : Monday, 15 January 2018 3:05:31 PM(UTC)
htprem
Thanks for the very informative replies to my post.
htprem
