Fastlane
Holden Forums
Holden General Discussion
Looking For Syd Build Monaro GTS 350 Manual No 205 to 210 , I may have your genuine motor
Looking for Monaro HT GTS 350 4 Speed Sydney Build , Body no. 205 to 210. I may have your original motor . The car is suppose to be Vedoro Green . Hoping the car may still exist . Would be nice to reunite the car with its original motor . Edited by user Friday, 16 February 2018 4:45:57 PM(UTC)
| Reason: Not specified
Thanks: 3 times Was thanked: 34 time(s) in 33 post(s)
Is it a manual or auto engine? |
The car may be out there, but probably more chance it was wrecked and the driveline went into a van or ute. Very lucky to find a HT GTS350 manual engine that hasn't been rebuilt and been decked in the process. Most of them were rebuilt in the 70's, although being a later Pagewood build it may have had an engine not from that initial batch. |
The motor came out of the car in 1977 , he did a big end then replaced it with a 6 cyl in the original car . Car was then traded in . Motor has been stored in pieces ever since !
Never bored never decked ! Original pistons etc
What rings are in it? Will be interesting to see what they are. |
Genuine Chevy ones . I’ll have a close look
The rings being the ones fitted at Tonawana. Most didn't have them when the cars were new. |
Well the original pistons are there why wouldnt the original rings still be on them Edited by user Saturday, 17 February 2018 7:04:52 AM(UTC)
HT GTS350 was delayed due to manual engines. GMH had to get them rebuilt locally but rings put in were wrong and most died pretty quickly. This is why it is so rare to find an unopened manual HT-HG GTS350 US engine. Plenty of auto and Canadian engines and 327’s. |
This one is a June assembly date not the April dates ones that I believe were the rebuilt ones
OK, should be OK then as won't be part of that initial lot of engines. |
"Planet earth is the asylum to which the rest of the universe sends it's lunatics" Voltaire |
Yes that is correct regarding 209 . So that leaves 205 ,206 , 207 , 208 or 210 . Vedoro Green
Thanks: 2 times Was thanked: 27 time(s) in 26 post(s)
I knew a fellow 15 years ago with a Vedoro Green in that range. He did not have the original engine but found one that was out by less than a dozen engine numbers.
Not sure what happened to the owner or the car.
Warren
was he in Sydney Warren ???
Fastlane
Holden Forums
