XX7Q Offline
#1 Posted : Tuesday, 6 March 2018 7:34:41 PM(UTC)
XX7Q
I am researching IDFS for a FB EK I am planning on purchasing, off course a HR front end is a cheaper option but by the time you source one then upgrade a 50 year old piece of suspension upgrading to a superior IDFS is not that far out of reach, about 4 choices I have found Castlemaine Rod Shop have one, Pat Gardener from V6 Conversions, South Chassis Works and the Rod Tech . Have read good things about the Rod Tech I am not planning on anything radical in regards to the motor at this stage just looking at maybe a Holden 6 with maybe an aftermarket EFI set up and a turbo 700 box just want it to steer and brake as it will be a daily ,any members had experiences with the above mentioned upgrades good or bad.
#2 Posted : Tuesday, 6 March 2018 7:55:27 PM(UTC)
I am about to buy s Rodtech setup for my HK GTS.
Standard setup, i’ll paint the arms black. Getting them to mod the column with a bush and supply the steering shaft.
I’m going to order the BA rotors 298mm( with AUII calipers (twin 42mm pistons) with HQ pattern. Primary reason for the BA brakes is the standard choice is XF which is fine for my HQ-WB rear drums but they supply VS calipers with the XF rotors, and VS pistons are a lot smaller (54mm) than the original HQ-WB 63mm pistons. Twin 42mm equate to a single 60mm piston and should work better with a HQ master cyl and HQ rear drums. I was going to use XF rear drums but decided to get a new diff (from Rodtech too) rather than use the old XW GT diff.
Note I will need 15” rims for the BA/AU brakes which are 15x6 Pontiac RallyeII.
My biggest concern is the Rodtech unit lowers the car 40mm, I can screw the shocks back up to 20mm but i’m looking for standard if I can.
Edit - i’m fitting aircon and a serpentine belt setup to this too for a more modern car too, so air, steer plus electric V2 CV8 seats. Initially will be a Quadrajet but I have an old McGee Airsensors 4bbl throttlebody injection setup that if I can drive it by a Delco and fit a HK GTS327 aircleaner I may do that later.
Edited by user Tuesday, 6 March 2018 8:18:10 PM(UTC)  | Reason: Not specified
XX7Q Offline
#3 Posted : Wednesday, 7 March 2018 1:23:14 PM(UTC)
XX7Q
Ok I like the sound of the BA rotors as well Byron, I will be fitting a HR Holden diff for rear upgrade and also wanting to run 15 inch steelies the ride height does not concern me as I want to lower the van the slightly
#4 Posted : Wednesday, 7 March 2018 1:37:24 PM(UTC)
What are you doing for booster and master cyl? Having a read of the Hoppers Stoppers site Peter Koning gives some good info near the bottom of the below link. He says that a Gemini booster (with lengthened pushrod) with XB master cylinder will fit an FE-EK on an auto car. By the sounds of what he says this will be perfect for the AUII/III calipers as twin 42mm are identical area to single 60mm Falcon piston. You just have to sort out the rears. I'd just use HK-WB backing plates and HQ drums with HQ-WB tonner rear axles which you'll just have to get shortened and re-splined to suit the HR diff width (might as well do 23 spline and use a fine spline centre). This will need HQ-WB ends welded on to the housing though to use tapered bearings. Bit more work that using HR axles but probably better than trying to re-drill HR axles to HQ pattern. Given the hassle though, why not just grab a HQ-HZ fine spline banjo or WB 6cyl small salisbury diff in the ratio you want, shorten it and weld on HQ-WB commercial spring mounts rather than HR ones? Then you just use HQ-WB commercial U-bolts and lower plates, HR shocks will connect straight to them. Look neater and you don't need to use those horrid HR-HG style spring hangers and rubbers. Shorten the tonner axles as above. Note you need tonner axles to re-spline as they are heat treated, normal ones aren't and are soft once resplined. Note that VB-VH 6cyl or 253 rear diff housing will work too to shorten just as well as a WB 6cyl housing. The 253 Commodore diff is probably better as it has a V8 banjo yoke on it already, so you can then run a V8 front yoke and use V8 unis both ends of the tailshaft.
Have a read of the 2nd link too, worth the time.
http://www.hoppers.com.au/stoppin%20holden.htm
http://www.hoppers.com.a...or%20Modified%20Cars.pdf
I looked at a CRS front end and 9" for a HR at my Engineer's shop last week. I wasn't impressed with the front end adjustments, they are done with nuts and threads as opposed to the almost infinite adjustment on the Rodtech setup. It looked good, just looked agricultural compared to the Rodtech one. It had Camaro calipers and rotors on it and Wilwood rears on the 9".
I also meant to mention, for 15" you'll just about have to run HQ pattern. Commodore won't work as most 15" Commodore rims won't clear the 298mm rotors and calipers, nor will Ford. Most of the factory or aftermarket GM 4.75" PCD 15" stuff will work.
Be wary too of track width. My Engineer told me they (Engineers) have been directed to not Engineer cars with a track change bigger than 25mm. So before ordering the front end and getting diffs made, find your wheels, figure out what wheel track they give you with the standard width front end and rear axle (compare wheel offset to original EK) and make sure that the wheels themselves don't increase the track by more than 25mm. I'm pretty sure the Rodtech front end gives you original track, but that might be able to be varied? The diff you can do whatever works.
Edited by user Wednesday, 7 March 2018 2:31:41 PM(UTC)  | Reason: Not specified
XX7Q on 7/03/2018(UTC)
This page was generated in 0.097 seconds.
