Hi All,
I have an EH special sedan which has a modified holden 6 with an M20 4 speed with the separate reverse lever. I need to replace the speedo cable and am wondering if anyone knows which cable it might use? I gather it's not the original cable as EH never came out with this gearbox. Any ideas?
Thanks in advance.
Thanks: 1 times Was thanked: 197 time(s) in 180 post(s)
The best off-the-shelf cable to use would be from the LC/LJ Torana 6-cyl 3-sp manual, Trimatic or 4-sp Aussie gearbox. Its genuine part no. is 2817827. I'm pretty sure Rares has this part. Most people try to use the cable off the larger HK/T/G Holden with the same gearboxes, because it has the same end fittings, but oddly that cable is shorter than the Torana item. Dr Terry Edited by user Wednesday, August 1, 2018 7:52:48 AM(UTC)
| Reason: Not specified |
Thanks very much Dr Terry, you've come through again.
Cheers.
