Thanks: 6 times Was thanked: 2 time(s) in 1 post(s)
I’m looking at buying a 186 with square type casting number Behind the oil filter it has the numbers c 28 9 on the block
Would this be for an hk? The seller hasn’t given me the engine number
Any info on the square type casting as opposed to the screwless and screw 186 number? Cheers
It will be late HK or early HT by that date code. |
