Thanks: 50 times Was thanked: 6 time(s) in 6 post(s)
Hi All As hinted at in the distributor thread, more engraving mysteries. The coil spring 'tube' (not sure what else to call it) on the front end has CSP engraved on it in 25mm tall letters. Like this:  Any ideas what this could be? Cheers Jacko
Thanks: 1 times Was thanked: 239 time(s) in 230 post(s)
Is this early HT (with the HK geometry) or a changed one (a month or so into HT) with the raised upper control arm mounting location? |
Originally Posted by: HK1837  Is this early HT (with the HK geometry) or a changed one (a month or so into HT) with the raised upper control arm mounting location? not sure about the difference between HK and HT sorry. It is from an Aug to Sept assembled HT. Has HT stamped into the lower control arms. here is a more general pic:  Jacko
That is the changed HT at that time. They sacrificed handling for improved straight like tracking by raising the upper control arm mounting points. It happened soon into HT production |
Joined: 2/02/2009(UTC) Posts: 538  ![Australia Australia]() Location: On a build over WWII airfield. Got the .50 cal cases from my driveway to prove it Thanks: 21 times Was thanked: 6 time(s) in 6 post(s)
Originally Posted by: HK1837  That is the changed HT at that time. They sacrificed handling for improved straight like tracking by raising the upper control arm mounting points. It happened soon into HT production I take it that the raised upper control arm pivot gives you more positive camber gain with wheel travel? More understeer, but less deflection from a straight line path when the wheel hits a bump, so better in a straight line. Buick had something similar with their full size cars in the same era. Great thread. Once more I've learnt something new. Thanks for it so far. Cheers, Chris |
Attn camry drivers. The accelerator is the skinny pedal on the right. |
Joined: 29/07/2006(UTC) Posts: 736 Location: in the shed
Thanks: 6 times Was thanked: 14 time(s) in 13 post(s)
Service Bulletin  |
"I would never want to be a member of a group whose symbol was a guy nailed to two pieces of wood" (George Carlin) |
 1 user thanked RigPig for this useful post.
what does that service bulletin date code decode to?
I'm guessing 1st of July 69 day shift.
 1 user thanked abi for this useful post.
