Welcome Guest! To enable all features please Login or Registers.
benny Offline
#1 Posted : Monday, 26 November 2018 9:20:59 AM(UTC)
benny
hi guys, is there any difference in ht 350m springs compared to other smaller engine ht gts cars, just trying to work out the correct springs for a mates build, was told that they had thicker leafs, can someone please fill me in thanks..
#2 Posted : Monday, 26 November 2018 11:16:38 AM(UTC)
HK GTS327 and HT-HG GTS350 manual are the same and hard to find. I think the only other place you find them is HK GTS and possibly HT V8 manual GTS. I can’t recall for certain if there are others, I know HT-HG GTS are different (same springs but different front eye), not sure about HT V8 auto GTS.
benny Offline
#3 Posted : Monday, 26 November 2018 11:20:58 AM(UTC)
benny
so are you saying ht hg 350m ran the smaller eye in the front, are they a 4 leaf spring.. thanks for your help..
#4 Posted : Monday, 26 November 2018 11:43:06 AM(UTC)
From memory yes, identical suspension to HK GTS327 (and same rear springs as HK GTS) except for raised upper control arm locations and slightly wider front track. It was the rest of HT and HG GTS, V8 GTS and auto GTS350 that started to go backwards (in terms of suspension performance), but I can’t remember exactly which ones changed and when. Although I do remember all auto GTS350 and all HT-HG GTS use different rear springs. It is the HT-HG V8 GTS that I cannot recall exactly.
abi Offline
#5 Posted : Monday, 26 November 2018 1:30:25 PM(UTC)
abi
I can confirm all HK GTS, GTS327 and HT, HG 350M cars ran the same rear spring, 4 leaves with the 1 inch front eye. Everything else in HT and HG ran springs with a 2 inch front eye except commercials which retained the 1 inch front eye.
#6 Posted : Monday, 26 November 2018 3:41:36 PM(UTC)
I just checked and HT V8 GTS manual also had the HK GTS rear springs, and HT GTS also had the same springs except they used the large front spring eye for a larger bush. So that means:
HK GTS
HK GTS327
HT V8 GTS manual
HT GTS350 manual
HG GTS350 manual
had the same rear springs.
Finding them today is near impossible, one or two of the leaves are unique. Last pair I saw sold for well over $2000. I have been lucky enough to get hold of 4 sets for the two GTS327's and the two HK GTS's that my mate and I have between us.
benny Offline
#7 Posted : Monday, 26 November 2018 4:03:17 PM(UTC)
benny
thanks for your answers, I really appreciate your help..
castellan Offline
#8 Posted : Tuesday, 27 November 2018 10:33:04 AM(UTC)
castellan
What's is the point you are after benny, just to be original or you are looking at it from the handling side of things.
I had ute springs in the back of my HG Premier.
benny Offline
#9 Posted : Tuesday, 27 November 2018 10:37:54 AM(UTC)
benny
mate wants every thing ridgy didge, original..
#10 Posted : Tuesday, 27 November 2018 10:52:47 AM(UTC)
I had to buy a whole HK GTS to get the last pair, but luckily it came with a whole heap of other goodies as well. It was one rusty POS Flintstone car that would have been impossible to repair.
