iitsmint Offline
#1 Posted : Friday, 28 December 2018 10:54:21 AM(UTC)
iitsmint
Hi im doing a v6 4 speed auto conversion to a eh and want to find a non conspicuous t bar auto shifter to fit that can sit in the eh console. Need a cable style shifter so as to not have to cut a big hole in the floor.
As it’s going o fit through the eh console I need the position indicator lens to fit into the top. Something like a cortina style t bar would look ok but it’s gotta have the gates and markings for a 4 speed. Not interested in a b and m set up, anyone got some ideas or pictures? To post
Edited by user Friday, 28 December 2018 11:05:01 AM(UTC)  | Reason: Spelling
#2 Posted : Friday, 28 December 2018 11:12:10 AM(UTC)
I did look for something like this when I considered a 4L60E in my HK GTS. I couldn't find anything other than fitting a B&M under the console and trying to make it look original. However Marks 4WD sell these that might be a left field solution? Not cheap though for the third option. The first two would allow you to fit a shifter under the console but not have an indicator on the shifter itself. The second one assumes you are using a 4L60E not a cable shift 4L60.
https://www.marks4wd.com...r-displays/mfk1145.html
https://www.marks4wd.com...solutions/gds-5011.html
https://www.marks4wd.com...-solutions/gsm5000.html
You could do this too and just put a very small hole in the floor using one of the remote indicators above:
https://www.ebay.com/p/L...Mushroom-Knob/1122220384
Edited by user Friday, 28 December 2018 11:15:50 AM(UTC)  | Reason: Not specified
iitsmint Offline
#3 Posted : Friday, 28 December 2018 5:52:54 PM(UTC)
iitsmint
Thanks for the reply, I checked them out, not really what I’m looking for, I’ve seen something that may work el Camino 67 arrangement may do it, but I’m thinking there’s got to be a mid 90s jap car that may have a set up that will fit, I’m sure there must be stacks of v6 and autos fitted to a range of old holdens, so someone must have explored this topic before
#4 Posted : Friday, 28 December 2018 6:05:27 PM(UTC)
Ask the guys in Moree. A lot of those Japanese 4spd only showed 3spds and were a pushbutton for overdrive.
#5 Posted : Friday, 28 December 2018 7:20:34 PM(UTC)
This could work off your column, scroll down to cable shift. Would need a digital gear indicator
http://www.lokar.com/auto-trans-access-parts.html
#6 Posted : Saturday, 29 December 2018 7:38:58 AM(UTC)
These are small footprint too
https://www.ebay.com.au/...ps%25253A%25252F%25252F÷÷ñÒ1705478005êÖ3õæwww.ebay.com.au%25252Fp%25252FB-M-BM80775-Other%25252F244389202%25253Fiid%25253D232423447633%252526chn%25253Dps%2526itemid%253D232423447633%2526targetid%253D468509345669%2526device%253Dm%2526adtype%253Dpla%2526googleloc%253D9071816%2526poi%253D%2526campaignid%253D1465521030%2526adgroupid%253D60534645727%2526rlsatarget%253Dpla-468509345669%2526abcId%253D1139236%2526merchantid%253D7364522%2526gclid%253DEAIaIQobChMIyNnPmL3D3wIV1aqWCh3GbQTcEAYYASABEgIlzvD_BwE%2526srcrot%253D705-139619-5960-0%2526rvr_id%253D1798408892736%2526rvr_ts%253Df6be57171670ac197f80b2aeffc40c11
#7 Posted : Saturday, 29 December 2018 8:26:13 AM(UTC)
Thinking about the column shift arrangement - you basically need some form of stepped gate with an additional 1 or 2 stops over an original 2 or 3 speed auto column shifter. There's also the spacing of these to consider, as the 4L60E has a significant distance between P & R, whilst 3-2-1 are quite close.
In your shoes, I would be doing the following:
1. Obtain the gearbox you're using for the conversion, and the shifter from the donor car (even if it's a linkage type floor shift and you don't like the appearance - read on).
2. Work out the leverage ratio required for a full sweep from P all the way to 1 - ie how far does it move end-to-end.
3. Work out the leverage that the EH column gives you from end-to-end. If it's the same distance - great. If it's shorter, then make a shorter end for the gearbox (so that reduced movement in the column gives you more at the box selector shaft).
4. Once you have these movements worked out, so the EH sweep matches the 4L60E sweep, then find where the detent (stepped) plate sits in the EH, and mark each position (PRNDL or PRND2L).
5. Using a blank steel plate, trace the EH one onto it, marking where P&L end up, and more importantly, where the pivot is..
6. Find the detent plate in the donor shifter (this is why you need it) and mark the various PRND321 steps before disassembly, as well as where the pivot sits - you can use a grinder to pull it apart as you won't need it again. 7. Lay the donor detent plate over the new tracing on the blank plate - aligning the pivot points. The 2 scales may not align yet.
8. Lay a straight edge from the pivot through the EH's P, and the 4L60E's P, and draw a line. So the same for 1, and then all the steps between.
9. If the scales do line up, then great, but if they don't, then you'll need to scale the steps using those marks you made, and then cut them into the new plate.
This will give the EH shifter the required number of detent steps for the 4L60E.
As far as the quadrant, keep the existing needle, and get a signwriter to cut you up some small stick on numbers, or a whole sticker, to apply to it. You can light this up with an LED if needed.
For the P/N safety switch, and reverse, have a look at what the column-shift VS utes did with their column & wiring. Actually, you may be able to get a VS ute column and avoid all the work I noted above, as it's set up for a 4L60E already, and knowing how little Holden changed columns over the years, some of the parts are likely to fit straight on to your column. The only downside is they have an ugly shift linkage arrangement that goes up & over the trans tunnel (across the firewall) but you may be able to replace just this section with a cable to make it neater.
#8 Posted : Saturday, 29 December 2018 2:57:57 PM(UTC)
I found this too. It I very low profile and would simply bolt to the floor and probably fit under most consoles.
http://www.autoobsession...terkit1964-67buick.aspx
morsesworld Offline
#9 Posted : Saturday, 29 December 2018 7:34:02 PM(UTC)
morsesworld
Hi iitsmint,
The indicator at the front of the boot on the auto shifter on P.18 & 19 of the Lokar Catalogue looks like it would do a good job.
The Cable kits include Neutral safety switch and Reverse switch built into it.
The only thing I didn't see was a shifter with a T bar option.
Dancing
