Thanks: 1 times Was thanked: 600 time(s) in 567 post(s)
As promised here are the HD through to the end of red motor 6cyl cam specs. I'll not get them all done in one go so will add as I get a chance. Timing is shown as INLET openBTC-closeABC, DURATION, EXHAUST openBBC-closeATC, DURATION, VALVE LIFT inlet exhaust HD 130HC, 149LC, 149HC and 179:15-45, 240deg, 50-10, 240deg, 0.338", 0.338". HD 179X2:23-53, 256deg, 58-18, 256deg, 0.338", 0.338". HR 161LC, 161HC and 186:
Same as HD except valve opening overlap of 25deg quoted. (No 130HC figures for HR). HR X2 and 186S:
Same as HD X2 except valve opening overlap of 41deg quoted. HK 130HC, 161LC, 161HC and 186:
Same as HR. HK 186S:
Same as HR. HT 130HC, 161LC and 161HC:
Same as HK smaller engines. HT 186LC, 186HC and 186S:
Same as HK 186S except any late HT with Trimatic and 186LC or 186HC gets the small engine cam. HG 130HC, 161LC, 161HC, 173LC, 173HC, 186LC+M40, 186HC+M40, 202LC and 202HC:
Same as HT smaller engines. HG 186LC (except M40), 186HC (except M40) and 186S:
Same as HT 186S. HQ 130HC, 173LC, 173HC, 202LC and 202HC:
Same as HG smaller engines. The preliminary Technical Specifications issued November 1970 show the 202HC with the X2/186S camshaft but this changed prior to release. LC 130HC, 138HC, 161HC an 173HC:
Same as smaller Holden engines. LC 2600S and 2850S:
X2/186S camshaft. LC XU1 (Sept 1971 revision, I don't have the June 1970 revision yet):
38-86, 304deg, 77.3-46.30, 304deg, 0.429", 0.429", overlap 84deg. LJ 130HC, 138HC, 161HC an 173HC:
Same as smaller Holden engines. LJ XU1:
44-80, 304deg, 83-40, 304deg, 0.429", 0.429", 84deg overlap. Looks almost the same cam as the final LC XU1 cam except retarded 6deg in the timing gear. The 8/71 XU1 cam specs are 38-86, 304deg, 77-46, 304deg, 0.429", 0.429", 84deg overlap. Revised to the above in 12/71. HJ 130HC, 138HC, 173LC, 173HC, 202LC and 202HC:
Same as HQ. HX 173LC, 173HC, 202LC and 202HC:
Same as HQ for export engines and manual ADR27A engines. 29-59, 268deg, 64-24, 268deg, 0.338", 0.338", 53deg overlap (ADR27A auto engines, revised April 1976 which was about when the trial ADR27A engines went into some Pagewood HJ). HZ 173LC, 173HC, 202LC and 202HC:
Same as HX. LH 138LC, 138HC, 173LC, 173HC, 202LC and 202HC:
Same as HQ. LX 173LC, 173HC, 202LC and 202HC:
Same as LH until ADR27A. ADR27A auto engines as per HX auto engines. UC and VB I do not have full data yet on exactly what engines were available across all markets, but at this stage assume they are the same as HZ camshaft wise. LC XU-1 camshafts. In the figures above I only quote the final spec of this camshaft as used in those final LC XU-1 vehicles, I unfortunately do not have the earlier un-revised Engineering Technical Specs for this. However Fiv Antoniou quotes the following (with my notes after it): LC XU1 (at release as quoted in service letter dated 3/9/1970):
29-57, 266deg, 64-24, 266deg, 0.345", 0.345", 53deg overlap (this is corrected in pen in Fiv's book changed fractionally in the timing, so 30-58, 65-23, not sure if this was done on the actual released letter or if someone has added it later). The duration doesn't add up here on the exhaust on either spec (64+24+180 = 268deg not 266deg), but the duration on the changed spec is 268 on both inlet and exhaust . LC XU1 (Fiv claims this is an updated cam specified for LC XU1, calls it Bathurst 1970 cam, but with no part number change):
23-65, 268deg, 58-30, 268deg, 0.345", 0.345", 53deg overlap. These figures do add up OK to 268deg on both intake and exhaust. To me it looks like the same camshaft as the earlier camshaft but advanced by 6deg in the timing gear. I'd say the original cam was actually 29-59, 268deg, 64-24, 268deg (which happens to be the ADR27A automatic 6cyl camshaft apart from 7 thou lift discrepancy!). Advance that by 6deg and you get the second camshaft. Note that Fiv has also stuffed up the LC 2600S camshaft specs, he has the intake open and close correct for both no-ramp and ramp, but has the smaller cam's figures for everything else. Also thought I'd throw in the VK EFI cam. 20-76, 276deg, 60-36, 276deg, 56deg overlap. If I remember correctly this is retarded 6deg in the cam gear, so if stood at 0deg it would be 26-70, 66-30. Not that different to the initial LC XU1 cam. I remember reading somewhere in the dim dark past that the inlet closing time was extended to take advantage of the ram tube effect of the intake which gave up to a 15kpa boost to atmospheric pressure. VC XT5 cams is: 19-65, 264deg, 60-36, 276deg. As you can see the only difference between the XT5 3.3L and the black EFI is the extra duration on the inlet closing. So in summary this means four basic camshafts total for all 6cyl production red engines plus the XT5 cam and the VK EFI cam:
15-45, 240deg, 50-10, 240deg, 0.338", 0.338", 25deg overlap (All smaller engines (except 2600S, 2850S) plus HK 186).
23-53, 256deg, 58-18, 256deg, 0.338", 0.338", 41deg overlap (X2, 2600S, 2850S, 186S and HT-HG 186 excl. Trimatic).
29-59, 268deg, 64-24, 268deg, 0.345", 0.345", 53deg overlap (LC XU-1 plus ADR27A automatic although 0.007" lift discrepancy in figures).
38-86, 304deg, 77.3-46.30, 304deg, 0.429", 0.429", overlap 84deg. (Final LC XU1). (44-80, 304deg, 83-40, 304deg, 0.429", 0.429", 84deg overlap LJ XU1 retarded 6deg).
19-65, 264deg, 60-36, 276deg. (XT5 blue and black)
20-76, 276deg, 60-36, 276deg, 56deg overlap. (VK EFI).
Can't find lift figures for the XT5 and EFI cams at this stage.
Edited by user Friday, 8 March 2019 11:12:05 AM(UTC)
| Reason: Not specified |
