HK-Q-Z5.0Lfan Offline
#1 Posted : Monday, 20 January 2020 6:25:25 PM(UTC)
HK-Q-Z5.0Lfan
G'day guys
Going to replace the Wheel bearings in my HX panelvan. Is it worth getting 1 tonner kits with the heavier retainer? Or no real advantage, or just overkill for a shed dweller/weekend cruiser. Id appreciate your thoughts
Thanks for any advice
#2 Posted : Monday, 20 January 2020 7:44:50 PM(UTC)
Originally Posted by: HK-Q-Z5.0Lfan Go to Quoted Post
G'day guys
overkill imo
I use the std kits on the Salisbury in the race car
no problems in nearly 15 years
but buy decent kits (no chinese garbage)
Edited by user Monday, 20 January 2020 7:45:58 PM(UTC)  | Reason: Not specified
#3 Posted : Monday, 20 January 2020 7:47:59 PM(UTC)
Either works, just buy good quality like Smitty says.
#4 Posted : Monday, 20 January 2020 8:25:40 PM(UTC)
HK-Q-Z5.0Lfan
OK. Thank you
#5 Posted : Thursday, 20 February 2020 5:28:22 PM(UTC)
HK-Q-Z5.0Lfan
Footnote....
Timken wheel bearings were $35 each & about $10 more for the 1 tonner ones. So after the advice on here, I ordered the standard ones, & the next day they turned up & they had the heavy duty retainer in them. Not sure if that was luck, or may only do the 1 kit now. Anyway I saved some money
Ian
greghqtonner Offline
#6 Posted : Tuesday, 22 December 2020 4:46:10 PM(UTC)
greghqtonner
how did you go ? i have 3.36 Salisbury in my tonner and when i put tonner bearings with the larger retainer on my half shafts the would not go back into the axle housing ( too large diameter )
had to go back to the standard set , same bearing number just different inner retainer ? have noticed a difference in the outer retainer quality / structure in some sets
#7 Posted : Tuesday, 22 December 2020 5:21:08 PM(UTC)
From memory the retainer is wider not larger.
#8 Posted : Wednesday, 23 December 2020 6:02:57 AM(UTC)
HK-Q-Z5.0Lfan
Yes, the 1 tonner bearing retainer is wider, but no bigger in diameter
