Hello. Long time between posts, is it possible to put a Turbo 400 into a Ht-Hg? Cheers, Mick. |
Water makes it's own sauce |
Thanks: 1 times Was thanked: 606 time(s) in 573 post(s)
Yes you can, but you need to modify the floor significantly which will need to be Engineered as you have to modify the main floor member that supports the front seats.
I would have put one or the 4spd version (4L80E) in my HK but too much mods to what is the oldest known surviving HK V8 GTS, so I’m running a TH350 instead. |
Joined: 2/11/2017(UTC) Posts: 63 ![Australia Australia]() Location: frankston Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
Hi Mick, There is a guy in Queensland who is putting a T400 into his Monaro on You Tube at the Moment. The Post is called "Motor Fab Channel". He showed the Alterations done to his Floor Crossmember in one of the Earlier Episodes. I hopes this Helps. Cheers.
