Anyone got Colours for following codes for LC Torana
Paint 567 12185 Top 568 13134 Trim 1335 48P
1335 is Glacier White over Burnished Bronze Metallic. In earlier LC this was 1296 but it was Kashmir White over Burnished Bronze. This must be for a car getting close to or past HQ.
48P is Sandlewood Vinyl on an SL. |
Joined: 25/05/2020(UTC) Posts: 4 ![Australia Australia]() Location: Townsville Thanks: 3 times
Originally Posted by: HK1837  1335 is Glacier White over Burnished Bronze Metallic. In earlier LC this was 1296 but it was Kashmir White over Burnished Bronze. This must be for a car getting close to or past HQ.
48P is Sandlewood Vinyl on an SL. Hello Have a LC with interior code of 1303 48F. Could you help id.
1303 is the exterior colour combination code for Glacier (roof) over Cinnamon Brown (body).
48F is the code for the interior trim, in this case Sandalwood.
Dr Terry |
Originally Posted by: Dr Terry  1303 is the exterior colour combination code for Glacier (roof) over Cinnamon Brown (body).
Dr Terry Hello Would you know what the VIN 82311CH171536 means please.
82311 = 2-Dr S 6-CYL Sedan C = LC Series H1 = Assembled in Acacia Ridge plant (Brisbane) 71536 = Sequential build number
As you can see, not a lot of model info can be gleaned from these early VINs.
Dr Terry |
Originally Posted by: Dr Terry  82311 = 2-Dr S 6-CYL Sedan C = LC Series H1 = Assembled in Acacia Ridge plant (Brisbane) 71536 = Sequential build number
Dr Terry Hello I have a vehicle here with no id plates on it. I have these numbers from the rego. Can you advise.6T153BK360X00838. Thanks
That is gobbledygook. Not a GMH number for Australia. |
Joined: 2/03/2018(UTC) Posts: 129  ![Australia Australia]() Thanks: 5 times Was thanked: 4 time(s) in 4 post(s)
Originally Posted by: Nifty
Hello
That's a Camry. I could de-code it, but why bother?? Not a holden
Yes it is Camry.
ACV36 model built between 9/02 & 6/06 with a 2AZ-FE 2.4-litre 4-cyl engine.
Dr Terry |
Dr Terry Hello Strange. I have the rego sticker on a car , which is a Torana and has the writing on it that says, GTR XU1.
