Joined: 13/01/2021(UTC) Posts: 5 ![New Zealand New Zealand]()
How much vacuum should a standard 186 have at idle compared to a 186 with a stage 3 cam? I’ve got 17” hg at idle
Thanks: 1 times Was thanked: 244 time(s) in 218 post(s)
Normal idle vacuum for a stock 186 should be around 19-inches.
The bigger the cam, the lower vacuum. A big cam will have a low vacuum at idle.
Stage 3 cam doesn't mean much these days, that's very much a 70s thing.
It's the actually the duration & lift that is important.
Dr Terry |
Originally Posted by: Dr Terry  Normal idle vacuum for a stock 186 should be around 19-inches.
Dr Terry https://www.ebay.com.au/...T-EPC1321-/183468266577
That’s the cam there, yes I know it’s not a good brand 😬
