HK-Q-Z5.0Lfan Offline
#1 Posted : Friday, 2 July 2021 12:31:45 PM(UTC)
HK-Q-Z5.0Lfan
G'day
I'm enquiring if anyone knows if T5 boxes have interchangable internals at all...
I have a VN sedan & VP ute, both 5.0L manual.
I also have a couple EA - EF falcon (6cyl) t5 box's kept in case of some H series modification plan.
Ive been given a t5 out of VN -VR 6 cylinder & I know the clutch fork is worth keeping, but my question is, is any parts out of a 6 cylinder commodore box compatible for spares? Or mix 'n match ratios at all?
Cheers for any advice
Smitty2 Online
#2 Posted : Monday, 5 July 2021 3:46:54 PM(UTC)
Was thanked: 26 time(s) in 26 post(s)
AFAIK... there are 6 different T5 style transmissions that have been used behind a variety of engines
in any number of chassis from a variety of manufacturers (even HDT had one to their specs.. T5G)
with different shaft splines, different shifter positions and I know there are different
service/repair kits (look to that number on the side) I suspect.. guess, that interchangability
of gear ratios may be a tad difficult...
Edited by user Monday, 5 July 2021 3:47:56 PM(UTC)  | Reason: Not specified
