Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
Shannons GTS327, Body Tag mistake appears to be Factory ? Great attempt to restamp the Engine Number.
I wonder what box is in it? Richmond 5spd or something?
It might all be OK however I'm a little suspect on the 818 on the VIN tag, but hard to see with the Shannons logo over it. The 818 looks a little less sharp than the 37 and also compared to other tag images I have nearby. No chassis number quoted to compare but the BODY and VIN numbers are about right, I think. The characters on the BODY tag aren't in quite the same locations as others I have nearby either, especially the VR. Given the fact the tags have been off, the engine number is re-stamped and the error on the BODY I'd be looking very hard at it and doing some research before buying!
Buyer beware certainly applies here.
