Originally Posted by: HK1837 I still defy anyone to find anything worse to try and do by yourself, than greasing the drive universal joint on a 743 or 743B Bobcat. I you were built like a small Asian person but with arms like a 6β5β person, have a 6β long grease hose and an assistant then maybe itβd be easier. These machines (and the 643 & 843) have one major fault, and that is these uni joints failed and smashed the hydrostatic pump. The reason they failed was people failed to grease them as it is too hard.
The worst car related ones for me (but not as bad as the Bobcat) are:
Changing an LH-LX brake booster without removing the dashboard.
Removing the exhaust manifold bolts and fitting extractors to a 2005-2015 Hilux with the good engine.
Removing and replacing the LH exhaust manifold on a HJ-HZ 308 auto with air (to repair broken flange studs).
The second two are far easier with a hoist, but you still have to be a contortionist and need an array of spanners and sockets and uni joints, plus feel rather than see.
sounds difficult but tried heater core on a SAAB 9000T....
NOT done from inside the car but from the engine bay!
first you remove the turbo exhaust system (yup inc its own separate oil supply setup) followed by the entire FI system -lines, hoses etc
then cam timing system (two special tools required.. special order from factory spares dept overseas, thankfully I know before) inc cogs and belts
then separate engine from auto trans a frag, and undo one engine mount
why this?... silly me, of course to then remove the cylinder head which is done by tilting engine block about 15deg forward
all done so far?... right!
then you remove PART OF THE FIREWALL
from inside the engine bay and ... oh lordy, look! finlly, the heater core and HVAC case
Remove both thru hole in firewall and R&R the heater core .. and go into reverse to install/replace .
Factory service book says allow 18 hours from start to finish.. took me a week
Edited by user Thursday, August 19, 2021 4:34:18 PM(UTC)
| Reason: Not specified
