Hi all, I have a Holden 202, stamped 3.3 on the block with a VL469## engine no. From what i can work out i think this is an early commodore red motor. Anyway I am trying to establish a rough value for this engine if i were to sell it. I have owned this engine for approx 15 years and has been on engine stand and regularly turned / rotated. When i purchased it years ago it was re honed with new rings and bearings done. Some details - Triple 2" SU's 40/80 Crow cam Starfire rods Straight cut gears Roller rockers Yella Terra head with screw in studs Was balanced and on dyno many years ago 268hp @ intake, 208hp exhaust New alternator, new harmonic balancer
Engine looks good, not like some old junker but just trying to get a rough value estimate from the gurus out there
Thanks Kev
Thanks: 1 times Was thanked: 485 time(s) in 463 post(s)
Better off asking on GMH-torana forum, they are in to red 6's. Someone would probably buy it off you there. Yes its a standard VB 3.3L block, identical engine to what went into HZ and UC just with different sump and a few other bits to fit the V car. |
