Joined: 2/11/2016(UTC) Posts: 1 Location: Rockhampton Thanks: 2 times
Hey guys. I recently got a ford XH ute 96 for my first car. I want to swap out the whole front end and put an XF fornt on like i orignally wanted. is it possible to achieve without modifying the body or chassy in anyway and if so will it fit.
I doubt very much that the XF panels will fit onto an XH. The whole front frame of an XH is more like an EF/EL & is nothing like an XF. Steering & suspension for example are totally different.
Dr Terry |
Dr Terry is dead right. A mate of mine wanted to go the other way and fit an XH front to his XD sedan. Never got done as it was A/ too hard B/ The XD is now worth more as an original V8 Fairmont Ghia.
Finding an XG is a better bet as they are basically an XF with an EB2/ED 4 litre engine fitted & a different grille to identify it as an XG.
FWIW the front sheet metal is a bolt on exchange between any XD XE XF XG or their equivalent Fairlane and LTD variants.
1 user thanked Jim5.0 for this useful post.
XF and XE front clip will bolt up to an XH with no modifications to the XH Body structure
