Thanks: 1 times Was thanked: 485 time(s) in 463 post(s)
Been working on an undercover steel welding bench so I can use it for general fabrication. Will have vices, bench grinder etc. on it.
Picked up a pair of Dawn vices for it today. A beaut metric (1970's) 150mm offset forged steel vice (blue one). Just needs a good clean and grease and I'll give it a coat of Ford engine blue paint plus I ordered a new pair of jaws for it. And a restored 150mm metric Engineers Vice (1970's or early 80's), the standard cast iron type in red. $260 for the pair. |
Joined: 6/07/2019(UTC) Posts: 356 Location: bayside Melbourne Thanks: 222 times Was thanked: 27 time(s) in 27 post(s)
Originally Posted by: HK1837 Been working on an undercover steel welding bench so I can use it for general fabrication. Will have vices, bench grinder etc. on it.
Picked up a pair of Dawn vices for it today. A beaut metric (1970's) 150mm offset forged steel vice (blue one). Just needs a good clean and grease and I'll give it a coat of Ford engine blue paint plus I ordered a new pair of jaws for it. And a restored 150mm metric Engineers Vice (1970's or early 80's), the standard cast iron type in red. $260 for the pair. nice one.... ! I have the std 'red' cast iron one I inherited from Dad (when we cleaned out the garage when he died) he had it since I was a kid, still a great vice! |
I also have a 150mm Engineer's vice that I bought new about 18 months ago. It is the light green SG (spheroidal graphite cast iron, also called nodular iron). I think this type replaced the old forged steel type and is supposed to be just as tough. I wanted a new one for precise clamping rather than an older one with wear in it. The pair I got yesterday will be perfect for what I want to do with them though. |
Originally Posted by: HK1837 I also have a 150mm Engineer's vice that I bought new about 18 months ago. It is the light green SG (spheroidal graphite cast iron, also called nodular iron). I think this type replaced the old forged steel type and is supposed to be just as tough. I wanted a new one for precise clamping rather than an older one with wear in it. The pair I got yesterday will be perfect for what I want to do with them though. also remember you can still get new jaws for DAWN vices (various types from specialist engineering /tool shops) best thing i did for the vice i inherited :) http://www.dawntools.com.au/vices/Vice-Jaws |
Yes, already ordered a pair for the offset vice. It's off to the sand blasters today to give it a quick clean up then I'll give it a coat of the Ford dark blue and back together. |
