Thanks: 9 times Was thanked: 1 time(s) in 1 post(s)
Can anyone tell me what the dickens is 1179-11R trim on a HT Premier
Thanks: 1 times Was thanked: 487 time(s) in 464 post(s)
1179 is Platinum Metallic.
11R should be Antique Gold vinyl. |
Thanks and I don't question your info because I know you know this stuff but I am curious about the "R" designation- I looked Winners Products for a guide and I see 11X is listed as "Antique Gold" but I am curious about the "R" v the "X". I figure I am missing something but can you clarify the "R" thing-thanks again.
AFAIK 11X is Antique Gold Monaro vinyl trim with Wyvern pattern inserts. 11R is Antique Gold Premier vinyl trim.
Dr Terry |
I don't think there was an insert available in HT Monaro Terry? GTS had a 11Y trim which was antique gold with black and white houndstooth insert. 11X is just the standard antique gold Monaro and GTS trim. Or is Wyvern the Monaro and GTS patterned vinyl insert?
Doesn't really matter though, 11R is the standard HT antique gold trim. I think 11T is the HT Premier antique gold trim with cloth insert. |
Originally Posted by: HK1837 I don't think there was an insert available in HT Monaro Terry? GTS had a 11Y trim which was antique gold with black and white houndstooth insert. 11X is just the standard antique gold Monaro and GTS trim. Or is Wyvern the Monaro and GTS patterned vinyl insert?
Doesn't really matter though, 11R is the standard HT antique gold trim. I think 11T is the HT Premier antique gold trim with cloth insert. Yes, I believe Wyvern pattern is the standard vinyl for HT Monaro including GTS, in the same way HK Monaros got Griffin grain. Dr Terry |
