Joined: 15/09/2022(UTC) Posts: 73 Location: Perth Thanks: 33 times
Hi all
Anyone aware of a decent headlight kit with halogen globes to suit my twin headlighted HJ 1 Tonner
Thinking 55w in the inner (low) & 100/55 outer (hi Low)
There are several brands on the market. I always preferred the Hella H4s, AFAIK they are still available.
Also I believe that outer beam is the low/hi & the inner beam is hi only.
Originally Posted by: Dr Terry There are several brands on the market. I always preferred the Hella H4s, AFAIK they are still available.
oops, yes thats correct , inner high & outer high low
Thanks: 1 times Was thanked: 485 time(s) in 463 post(s)
I always liked the sealed beam aircraft landing lights for the inners on Quad headlight fronts. I used to run 130W but you can get them in 100W. Outers just the H4 100/55. For twin headlight fronts I used H4’s with 130/80. Make sure you use relays though for 100W lamps, you don’t want to run 20-30A through the high beam switch and wiring. Edited by user Saturday, 12 November 2022 3:59:08 PM(UTC)
| Reason: Not specified |
Joined: 21/12/2018(UTC) Posts: 85 Location: SA Thanks: 22 times Was thanked: 9 time(s) in 9 post(s)
I have a single headlight tonner and use the Hella inserts with H4 100/55 globes. No problems, they have been working fine for well over 10 years with only one filament blowing. The inserts also feel solid, there is a good amount of glass there which IMO makes them stronger. I did have to notch the sheet metal headlight holder to get clearance for the park light however. About a square inch or so of metal removed IIRC. Again no problems, it just took a bit longer to fit them. EDIT: It wasn't the sheet metal surround, it was the metal headlight-shaped holder that needed some metal removed. I use a relay. I would recommend you get a relay from an auto-sparky. There are relays designed specifically for headlights and the one the sparky recommended has performed flawlessly despite years of dust and filth. As a side-note, the sealed beam headlights that were on the tonner when I bought it could best be described as "about as bright as two candles"! When the Hella replacements went in it made a VERY BIG difference, much brighter! Edited by user Monday, 14 November 2022 2:28:33 PM(UTC)
Decided to go with the Hella 1055 (H4) for the outers with 100/55w lamps & 1053 (H1) for the inners with 55w lamps
Hopefully they fit !
Use a relay for the hi beam lamps. |
