#1 Posted : Friday, 5 May 2023 1:19:48 PM(UTC)
All. Some obscure PO codes for you to solve. These are for HK but some will be applicable to other Series.
L22 - 130ci export red 6.
J50 - Power brakes (4 wheel drums)
GN2 - Rear axle radius rods (GTS and only with L30 and M21)
K69 - Ignition Key (3 key set)
L34 - 327ci V8 engine. Only really had a code as it was initially to be be part of an option package on GTS.
L61 - Economy Carb (only with BO2 taxi equipment)
NA4 - Fuel tank stone guard
NG1 - Fuel Tank 25 Gallon
N84 - Red band tyres. Standard on GTS (on P69) and GTS327 (on PX4). Only with P69 (6.95x14 Premium-S), P70 (7.35x14 Premium) or PX4 (D70x14 High Performance H) tyres.
T47 - Hood ornament (standard on Brougham, optional everywhere else)
U16 - tacho
U18 - export kmh speedometer
U80 - rear seat speaker
V81 - Trailer Provisions
V86 - Fire extinguisher (added feb '69)
XT4 - Tinted windscreen glass (only prior to 1/1/70)
C80 - Switch front door jam
CA2 - Delete Black soft roof covering (only applicable to Brougham)
E91 - Cover - tonneau clip-on
A33 - Power operated end gate window
D99 - Two tone paint
Edited by user Tuesday, 23 May 2023 5:54:07 PM(UTC)  | Reason: Not specified
#2 Posted : Friday, 5 May 2023 3:48:31 PM(UTC)
U16 or U18 sports dash?
KBM Offline
#3 Posted : Friday, 5 May 2023 3:49:08 PM(UTC)
KBM
L22- export 250 6cyl
J50- vacuum power booster
U16- console tacho
U18- export speedo kph
U80- rear speaker
A33- rear tailgate power window
D99- two tone paint moldings
Edited by user Friday, 5 May 2023 3:50:12 PM(UTC)  | Reason: Not specified
#4 Posted : Friday, 5 May 2023 4:05:25 PM(UTC)
I believe that L22 was 130ci 6-cyl export engine. The 250ci Chev 6-cyl was LD4.
Was L34 the original engine option for the 327 SBC V8.
I've seen XT4 as a tinted windscreen.
The ones I have queries with are NA4 & NG1, could they be N44 fast ratio steering & N91 sports wheel discs (GTS wheel covers).
N84 & T47 are quite odd.
#5 Posted : Friday, 5 May 2023 5:49:08 PM(UTC)
Was thanked: 34 time(s) in 33 post(s)
CA2 possibly related to windscreen wipers. Seen a similar code in HJ production sheet
#6 Posted : Friday, 5 May 2023 5:49:31 PM(UTC)
I’ll amend the original post with correct answers. Some are correct already or close.
#7 Posted : Saturday, 6 May 2023 9:56:54 AM(UTC)
Added the correct answers so far.
Terry, NA4, NG1, N84 and T47 are all valid HK PO's.
CA2 isn't anything to do with wipers.
justgm Offline
#8 Posted : Saturday, 6 May 2023 10:22:05 AM(UTC)
justgm
CA2 - Delete vinyl roof ?
#9 Posted : Saturday, 6 May 2023 11:48:53 AM(UTC)
Some more guesses from me, hopefully closer this time. Looks like Mark got the delete vinyl roof right.
Is N84 delete spare tyre?
C80 door switches for interior light?
E91 pocket on rear of front passenger seat?
#10 Posted : Saturday, 6 May 2023 12:35:24 PM(UTC)
C80 is close, I added it. N84 is a tyre option but not delete spare tyre - that is P32 (delete tyre) and N61 (delete spare wheel). If you wanted to delete both it was N61+P32.
E91 isn't as stated, nowhere near it. E87 and E91 were two versions of the same thing.
justgm Offline
#11 Posted : Saturday, 6 May 2023 1:17:44 PM(UTC)
justgm
GN2 -Radius rods GTS
K69- 3 Keys
L61 -Economy carb.
I found the book with the answers in! let the quiz run a bit longer for some fun . Thanks Mark.
bazza30555 Offline
#12 Posted : Tuesday, 9 May 2023 10:32:47 PM(UTC)
bazza30555
NA4 fuel tank stone guard
T47 hood ornament
V86 fire extinguisher ( graviner bcf 2LB)
#13 Posted : Thursday, 11 May 2023 11:06:39 PM(UTC)
Was thanked: 28 time(s) in 27 post(s)
E91 Tonneau cover clips.
#14 Posted : Friday, 12 May 2023 7:51:12 AM(UTC)
Good to see you around Warren. Almost correct but close enough. E91 is "Cover - tonneau clip-on", as opposed to E87 "Lash on tonneau cover"
bazza30555 Offline
#15 Posted : Friday, 12 May 2023 10:56:36 AM(UTC)
bazza30555
N84 redwall band tyres
V85 also a fire extinguisher
#16 Posted : Tuesday, 23 May 2023 5:54:38 PM(UTC)
Looks like this has run its course. Added the last two, NG1 and V81.
SBozza Offline
#17 Posted : Thursday, 17 August 2023 10:54:52 AM(UTC)
SBozza
Does a code exist for rear seat belts option on 2 door Coupes?
#18 Posted : Thursday, 17 August 2023 4:56:00 PM(UTC)
There was a few packages for different rear seat belts. The part numbers for coupe were 7439496 and 7 for respectively Britax and Cooldrive setups.
The option codes were:
A47 - rear seat belts lap and shoulder (sedan, wagon and Brougham only).
A64 - rear seat belts lap type (everything except ute and van).
A68 - rear seat centre belt lap type (everything except ute and van).
 2 users thanked HK1837 for this useful post.
SBozza on 18/08/2023(UTC), Smitty2 on 18/08/2023(UTC)
#19 Posted : Friday, 18 August 2023 4:05:52 PM(UTC)
Was thanked: 27 time(s) in 27 post(s)
slightly off topic.....
many eons ago when I had hair and had walked out of my high school accounting Form 6 year with a pass
I got a job- accounting audit trainee with a chartered public accounting firm
One of their clients for audit of their books was CoolDrive Consolidated Industries in Broadmeadows
and one of the first places I helped audit . I got picked up by the partner each month and taken out
to assist the audit team.
Did many things.. got taught how to count bolts Anxious , how to work out metal press strokes but better still
as many of the automotive customer staff did, got a ride on the seatbelt test sled. Dancing
woot.. accelerate up to 50kmh on the sled and wham, stop in less than 2 metres from that speed.
Made you very aware of the effectiveness of safety belts (as the CoolDrive engineers called them)
Edited by user Friday, 18 August 2023 4:06:46 PM(UTC)  | Reason: Not specified
This page was generated in 0.307 seconds.
